Latest post Mon, Dec 22 2014 10:08 PM by dekafilm. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Nov 7 2014 1:08 PM
    MediaComposer 8.2 - Subcap - No linebreak no accent are possible
    Hello
    on my system (AVID MC 8.2, Mavericks 10.9.4, macbook pro 16gb ram), it is impossible to have line break within a subtitile using Subcap. As soon as you enter a line break, the second line desappear when you go to the next subtitle. The same happens with accent letters like "é". Any special characters desappears...
    any solution?
    thanks
    Olivier
    Macbook pro 16gb, Avid MC 8.2, Mavericks 10.9.4, Dell U2711. [view my complete system specs]
  • Fri, Nov 7 2014 1:54 PM In reply to
    Re: MediaComposer 8.2 - Subcap - No linebreak no accent are possible
    I'd look at the Box Appearance parameter in the SubCap effect editor.  Specifically the drop-downs for box width and number of rows.
  • Fri, Nov 7 2014 2:19 PM In reply to
    Thanks for your reply.
    The problem is a bug. If your are in "edit master caption list" mode, you can enter a subtitle on one line, then type RETURN and enter the second line.
    if you close the "edit master caption list", go to your time line, and play the sequence, you can see there is no second line of subtitle on your monitor, whatever specification you set in the box width and number of row.
    if you reopen "edit master caption list", you can see that your second line has simply desappeared. only the first line stayed... it happens the same with é,è, and any other complex char...
    if you enter &a as a linefeed in the box "caption text", the same phenomenon happens: the second line desappear when you close the effect window...
    this is clearly a problem with characters like RETURN...
    all the best
    Olivier
    camoscato:
  • Fri, Nov 7 2014 2:24 PM In reply to
    Maury-Zuchuat:
    The problem is a bug. If your are in...
    Yes.  All of that information describing the problem in detail would've been helpful in your initial post.
    Anyone else seeing this?
  • Sat, Nov 8 2014 3:58 PM In reply to
    • Joseki
    • Joined on Mon, Aug 23 2010
    • Posts 33
    • Points 430
    camoscato:
    Maury-Zuchuat:
    The problem is a bug..
    yes...the problem is a known bug that have been escalated...
    you could go to the following thread to add your name ito those waiting for a fix
    745888.aspx
    Media composer 8.3.1 / Mojo Dx / Mac pro 4,1 / Mac OS 10.10.2 [view my complete system specs]
  • Sun, Nov 9 2014 8:42 AM In reply to
    Joseki:
    Thanks for that!
  • Mon, Nov 10 2014 2:00 PM In reply to
    • SteveK
    • Posts 319
    • Points 3,600
    The way Ihave found this with V7 (foreign accents and CR ) is to open an "EDIT MASTER CAPTION LIST" window from Effects Editor "Box appearence" on the SubCap effect.
    You can cut and paste or edit, use different fonts/characters and CR in there.
    Steve
    Numerous clients mojo to Nitris PC systems 6.5 to 2018.3 with interplay with ISIS/UNITY, EVS transfer/w IP director At Home: new 2017 15" i7 MacbookPro... [view my complete system specs]
  • Tue, Nov 11 2014 8:20 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    Joseki:
    camoscato:
    Maury-Zuchuat:
    Yes I can confirm seeing this, on 8.2 running on 10.8.5: I edit a timeline from a previous project, with french subtitles. I go to Master Caption List, as I always did when it comes to alter subs with funny accents, modify a sub, hit Enter. And anything after the accented letter disappear.
    Thanks for escalating it, and let's hope for a quick fix because it's crucial here...
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Mon, Dec 22 2014 10:08 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 115
    • Points 1,345
    Just tested v8.3.0, and it works again for me.  Seems like they fixed it!
    AVID Media Composer v8.x MacPro 2010 (5,1) 12-core running OSX Mavericks and Sierra, 24GB RAM stock ATI Radeon 5770 graphics card AVID Media Composer... [view my complete system specs]
    http://www.davidekabramson.com
