Latest post Sat, Sep 13 2014 10:39 AM by Job ter Burg. 84 replies.
Page 2 of 6 (85 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Sun, Feb 2 2014 10:30 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,456
    • Points 17,975
    Re: Your views on Frameflex, please
    Frameflex moves appear to be green dot, realtime.  Is that also true of AvidFX or do they need to be rendered?  And will AVidFX work with AMA'd files?
  • Sun, Feb 2 2014 10:57 PM In reply to
    • Posts 11,521
    • Points 235,025
    smrpix:
    They have to be rendered.
    Don't forget to balance "having to render" with can rotate on x, y, and z axes, add drop shadows, add effects from a selection of around 190 BCC etc.etc. at the same time as doing the equivalent of "FF" moves.
    BUT, yes there are also some gotchas in using Avid FX.
    I will point out the more important ones later in this thread. Geeked
    For now, I am still interested in hearing more views on FF and how it is being used.
    Thank you all for the many interesting views so far Yes
    Regards
    Douglas
  • Sun, Feb 2 2014 11:00 PM In reply to
    • Posts 11,521
    • Points 235,025
    smrpix:
    Woops, sorry, I forgot to answer that question.
    I don't know.
    I do not use AMA, and therefore have no answer to your question.
    I am sure some others can, hopefully, answer it though.
    Regards
    Douglas
  • Mon, Feb 3 2014 6:03 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,385
    Seems like you just answered your own question Douglas
    drbgaijin:
    I do not use AMA,
    Frameflex is for ama workflows so no ama - no frameflex
    Tomas
  • Mon, Feb 3 2014 6:06 AM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 377
    • Points 4,405
    Douglas, not that it really matters in the least but I thought you should be aware of a small correction with the last video you posted in this thread. AVX is Avid Visual eXtensions, not Avid Video eXchange ;)  Sorry... carry on my good man :D
    HP Z400 (W3520) 2.67 ghz quad core, 12GB ram, Quadro K2000 (Nvidia driver 310.90), Win 7 Pro 64, MC 5.5.3, Quicktime version 7.6.9, KVM switch, dual 20"... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
  • Mon, Feb 3 2014 7:42 AM In reply to
    • Posts 11,521
    • Points 235,025
    Wm.Busby:
    Thank you for pointing out my AVX error. Yes
    It does matter. I am unlikely to correct the mistake in the old video, but I will try to avoid making it in any future video tutorial.
    Regards
    Douglas
  • Mon, Feb 3 2014 7:54 AM In reply to
    • Posts 11,521
    • Points 235,025
    mjolnarn:
    drbgaijin:
    I do not use AMA,
    Not quite sure what you mean by that, Tomas. My question was about how everyone is using Frameflex.
    But never mind.
    mjolnarn:
    That makes things even worse in my opinion.
    If Frameflex (a-work-in-progress **) needs AMA (another work-in-progress**) to function correctly, then you should be prepared for a few disasters in the workflow.
    ** = my description of the two of them, not Avid's
    Regards
    Douglas
  • Mon, Feb 3 2014 8:01 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    drbgaijin:
    mjolnarn:
    Regards
    Douglas
    There is a learning curve Douglas, better start practicing if you are going to do a comparing tutorial between Frameflex and Avid Fx
    Tomas
  • Mon, Feb 3 2014 8:09 AM In reply to
    • Posts 11,521
    • Points 235,025
    mjolnarn:
    Geeked
    Luckily, Tomas, I have no plans to make such a tutorial.
    Regards
    Douglas
  • Mon, Feb 3 2014 3:08 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    Hrrrmm
    mjolnarn:
    drbgaijin:
    As to zooming and panning on a 4K movie clip - Yes! Avid FX can do that too!
    Today I got hold of a "4K" prores clip.  It was a few pixels short of full 4K, but close enough.
    I brought it into Avid FX. My Avid FX project was 1920x1080, so the 4K clip was approx. double that when it was present at 100%
    By reducing the scale by to 50% I had the full 4Kclip showing in my 1920x1080 Composite window. I could then zoom in to 100%, still keeping the quality of the 4K clip. Zooming further would, of course, result in deterioration of the sharpness.
    drbgaijin:
    smrpix:
    drbgaijin:
    BobbyMurcerFan:
    Hi Douglas, may I ask, are you doing this in AvidFX standalone or launching from inside MC? Thanks.
    From inside MC, BMF
    Douglas, as Avid currently only can work with HD all you have on your sequense is Hd so the only way to get a 4k clip inside Avid FX is to not use the Avid timeline as source.
    Even if it is ama linked 4k ( you don´t use ama, I know ) the clip on the timeline is HD resolution processed by Frameflex from the origin 4K resolution to HD.
    If you want Avid FX to handle 4k you also have to convert all the origin 4k files to a codec that Avid FX can understand when pointing directly to file.
    Frameflex in it´s current version is very limited but it is, from how I can see it, currently the only way to get 4k media directly into Avid from the origin source and pan and scan that media in it´s origin full resolution.
    Tomas
  • Mon, Feb 3 2014 4:51 PM In reply to
    drbgaijin:
    while "needs" should be replaced by "only functions in combination with" if you ask me, in essence I would say: confirmed!
    From the old Apple Quadro 950 to HP Z8xx. My current own system: 1x Z420 E5 1650 16GB memory, 1x XW8600, 2x 3.0Ghz Quadcore, 24GB memory, MC 8.6.5... [view my complete system specs]
    Jeroen van Eekeres
    www.mediaoffline.com
  • Mon, Feb 3 2014 6:58 PM In reply to
    drbgaijin:
    I see FrameFlex and AMA as parts of the same source footage functionality. That they are both up for improvement is another thing, but dissing them because they are parts of the same toolkit seems wrong to me. My 2 cts.
  • Mon, Feb 3 2014 7:37 PM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 377
    • Points 4,405
    drbgaijin:
    no problem, Douglas... you're welcome.
  • Mon, Feb 3 2014 7:52 PM In reply to
    Job ter Burg:
    drbgaijin:
    Job,
    I do not interpret Douglas's words as "dissing" but as a practical acceptation that
    Job ter Burg:
    and that everybody that is planning to use AMA and frameflex needs to be aware of the current functional status of these functions.
    Jeroen van Eekeres
  • Mon, Feb 3 2014 8:26 PM In reply to
    • Posts 11,521
    • Points 235,025
    Hey folks...
    Hope you all dont mind if I jump in.....  :)
    Essentially most of the comments in this thread are accurate. Notice how I said most :)
    It's best to work with FrameFlex with the larger than HD media linked.  When you transcode, there is a compromise to the media because we cannot transcode to larger than HD.  As you all know from the other thread on this.... we do not transcode using any of the animated FrameFlex (or any other effect) on the project timeline.
    It is best to NOT apply transformations when transcoding.
    This means you will now be reframing an HD image and thus you will loose quality as a trade-off for performance (everyone does realize that we transcode to HD right?).  Not “baking” the media gives the flexibility to make further changes to Frameflex and its animation; when you relink to the original media; you regain full quality and are ready to export.
    what is a cool feature ot this is that Customers can have different framing parameters for the same clip appearing at different locations on the timeline.
    When you drop the clip on the timeline, the FrameFlex (and color) source settings are applied.  This is how we know how to scale a larger than HD clip onto an HD project.  You can then open each single shot (on the timeline) and make additional FrameFlex changes, and those changes now become inherent to the sequence (essentially as effects).
    We recommend using the source settings as a general starting point for the clips - adjusting image aspect ratio and basic reframing - and then, once on the timeline, modify the FrameFlex settings according to the artistic decisions for each shot (reframing and animation).
    HTH and let the dialog continue.
