Latest post Sat, Nov 2 2013 5:47 AM by jwrl. 4 replies.
  • Wed, Oct 30 2013 9:05 PM
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 129
    • Points 1,375
    MC7 Update Activation Failed -- prior product not correct
    Earlier this year, I purchased a Symphony 6 to 6.5 upgrade from Avid, and I downloaded that upgrade and  the free 6.5 to 7 upgrade.  I have been running 6.0.1.1 since last year.  Today I uninstalled everything and installed the upgrade to MC 7.0.2.  When I tried to activate the new version with the Activation ID that I was given, Avid License Control refused, with the message, "101 Update Activation Failed.  Prior product is not correct for this upgrade license."
    Does that mean I have to install Symphony 6.5, then uninstall it, and finally install MC 7.0.2, or is there a way to skip 6.5 and go straight to MC 7.0.2?
    Core i7 930 PC 2.8GHz / 18GB RAM / Win10 Pro 64bit / nVidia Quadro K2200 (driver 411.95) / MC 2018.12.9 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Thu, Oct 31 2013 7:24 AM In reply to
    • Ken Lent
    • California
    • Posts 129
    • Points 1,375
    Re: MC7 Update Activation Failed -- prior product not correct
    I tried uninstalling MC 7.0.2, then installing and activating Symphony 6.5.4, then deactivating and uninstalling Symphony 6.5.4, then installing and activating MC 7.0.2, and now MC 7.0.2 works!
    But I am still wondering if there was a way to do this without installing 6.5 first. . . .
  • Thu, Oct 31 2013 12:12 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    If it makes you feel any better, dongle users had the same problem where they were required to update their dongles first to 6.5 and then to 7. For some reason the direct path from 6 to 7 did not work.
    MC 2020.10 | QT 7.7.9 | Continuum 2021 | Sapphire 2020.5 | Mocha Pro 2021 | Titler Pro 7.3 | Windows 10 Pro x64 (20H2) | System: Asus x299, i9-7940X (4... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Nov 1 2013 8:51 PM In reply to
    • Ken Lent
    • California
    • Posts 129
    • Points 1,375
    Thank you, Steve!  I'm pleased to have completed the upgrade, and your message confirms that the 6.5 pit stop was necessary after all.
    Ken
  • Sat, Nov 2 2013 5:47 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,420
    • Points 97,425
    BarkinMadd:
    dongle users ... were required to update their dongles first to 6.5 and then to 7.
    Yes, but it wasn't necessary to install un-needed software.  All that was necessary was to just update the dongle alone first to 6.5 then to 7.
    That's a lot less painful than doing a deactivate, uninstall old version, install 6.5, activate, deactivate, uninstall 6.5, install 7, activate!  Surely there has to be a simpler path for people using software activation.
    As far as I'm concerned it's yet another reason to stick with dongle activation as long as possible.
