Latest post Sat, Sep 21 2013 8:05 AM by Wm.Busby. 4 replies.
  • Wed, Sep 18 2013 2:31 PM
    • Lembit Soobik
    • Joined on Sun, Sep 2 2007
    • Freising - Germany
    • Posts 286
    • Points 3,755
    cannot sort by name ?? MC 6.5.3
    The following procedure used to work before (not sure about 6.5.3 version):
    clips, still pics, audio clips (wav) all have the naming convention yyyy-mm-dd_hh-mm-ss_(seq-nbr).ext
    examples:
    2012-10-07_13-15-26_00135
    2013-10-07_09-18-24_1001.WAV
    I put them all in one bin and double click Name
    resultis: film and jpg are put all in sequence,
    but all the WAV clips are placed at the end (or beginning), not where they belong.
    is there something new in 6.5.3 or have I messed up some setting
    BTW, the reason I put the time and date in the name is that creation date is changed when I edit the picture ore WAV.
    thanks for any help
    Lembit
    MC 2018.5 on Windows 10// HP Z800 WS: 2 x Xeon X5570, 48 GB RAM, Quadro M4000 32GB, disks: 1 x 500 GB SATA 7200 = System/ 1 x 1 TB Samsung 840... [view my complete system specs]
  • Wed, Sep 18 2013 6:27 PM In reply to
    Re: cannot sort by name ?? MC 6.5.3
    Click on the name column and press CTRL+E - that should re-sort by that column.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Thu, Sep 19 2013 1:36 PM In reply to
    • Lembit Soobik
    • Posts 286
    • Points 3,755
    Thank you, but that doesn"t do it either.
    attached screenshot shows the bin after sort. I checked the help and tried everything.
    and it's not just this bin. other bins show the same problem. .WAV files are always put on the end (
    or beginning), but never sorted with the other clips
    Lembit
  • Fri, Sep 20 2013 10:54 AM In reply to
    • Lembit Soobik
    • Posts 286
    • Points 3,755
    Well, I finally found the error - between keyboard and chair - :
    All the WAV files have got the year 2013 instead of 2012.
    What can I say? am I blind or dumb or both?
    Lembit
  • Sat, Sep 21 2013 8:05 AM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 377
    • Points 4,405
    I was just about to reply about the year difference, then I read your last post. We all have "DOH!" moments :)
    HP Z400 (W3520) 2.67 ghz quad core, 12GB ram, Quadro K2000 (Nvidia driver 310.90), Win 7 Pro 64, MC 5.5.3, Quicktime version 7.6.9, KVM switch, dual 20"... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
