Hello
I have an 84 minute HD sequence that I need to downconvert and put onto a standard SD DVD. I have the HD sequence exported as a QT reference file.
In my opinion - encoding in Avid DVD doesn't create a good DVD - If I create it as a wide screen DVD the final output fills my HD TV and there does not appear to be any cropping for black bars - this is good but the movement appears jerky and not smooth
So quality-wise it is not the best.
If I look at preferences I have the quality slider set all the way to the right for Best Quality - and my SD transcoding bit rate is set to CBR 7000 at so I dont think there is much I can do inside Avid DVD to improve this. (These appear to be all the settings there are)
Strike out for Avid DVD on quality
My next step then was to look at Soreson - and encode the sequence to a DVD compliant Mpeg2 preset and use that in Avid DVD with no re-encoding.
But now my issue is that the same sequence in Sorenson using the DVD Mpeg2 format constraint with a stream type of Program, Pal format at 7000 Kbps produces a file of well over 5Gb
So I reduced to 6500Kbps and it is still too big for a DVD -
In my effort to create an Mpeg file that will fit on a standard DVD I am now down to 5500Kbps bit rate - each encode takes over 2 hours so no idea what size this will turn out to be.
When I use any bitrate calculator the suggested bit rate for a DVD of this size is approx 6400Kbps.
Does anyone know why Sorenson couldn't be bothered to produce a file of this size at this rate but instead produces a much larger file?
Besides from using another encoder (I dont have TMPGenc) any ideas as to how to get the Sorenson files to comply to what but rate calculators recommend or any good tips on improving the quality in Avid DVD?
Neil
www.effectivevideo.co.za
To fit an 84-minute sequence onto a single sided DVD requires that you use Variable Bit Rate (VBR) and not Constant Bit Rate (CBR). Even then, the average bitrate is going to be rather low. If you use PCM (.WAV) audio (fixed at 1.536Mb/s) then you end up with a Max. bitrate of 8Mb/s, average of 5.6Mb/s, and a minimum of 2.2Mb/s. If you encode audio as 2-channel AC3 @ 384Kb/s then the numbers are 9.1/6.7/2.65 mb/s respectively.
If you really want to use CBR with a single sided DVD then you have a bitrate of 5.6Mb/s with PCM audio and 6.7Mb/s with AC3.
If you're using a double sided DVD, then you can encode using CBR at 8Mb/s with PCM audio, or 9.1Mb/s with AC3. Note that except for extreme motion, you don't really see much improvement with the higher bitrates once you hit about 7.5Mb/s. IMHO.
Hope this helps.
Dave S.
You might like to try this: create a dual layer (not double sided, as I originally posted) disc image in of your first conversion and save it to a hard drive. Then download ISOedit and install it. ISOedit can read most DVD images, and will further reduce your file size. It will then create a single sided ISO image, which you can then burn. Typically, there should be little to no subjective quality reduction.
As I understand it, ISOedit doesn't recompress the media, it eliminates redundant data. It is also very fast. I used it first in a desperation move, and was agreeably surprised at the result. And the client accepted the end result without question.
Try it. It won't add much time to your workflow, and it may just be the answer that you need.
"double sided DVD"... are those even still available anymore? :)
Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
Wm.Busby:"double sided DVD"... are those even still available anymore? :)
But dual layer disks are. Lazy checking of what I posted...
I've edited the original.
No problem... just yankin' your chain. Btw... Dave started it anyway
Wm.Busby:Dave started it anyway
Now back in the days of LaserDisc we did have double sided discs. And they were a real man-sized 12" disc, too! A-a-a-ah, the good old days.
