Latest post Sat, Jul 6 2013 10:33 PM by Vampyr. 4 replies.
  • Sat, Jul 6 2013 12:50 AM
    • Vampyr
    • Joined on Sat, Jul 4 2009
    • Saint Louis
    • Posts 13
    • Points 185
    Is there a way to create movie files from clips?
    I ripped a DVD using Cinematize Pro and I imported it into Media Composer 6.5.
    I dropped it into my timeline and began adding edits at all the original edit points. For example, every time the original editor made an edit, I duplicated that edit in my timeline.
    I ended up with probably about 50 edits, each are marked with a white dot.
    Is there a way that I can turn each of the 50 clips into it's own .mov file?
    I would like each clip to appear in the bin as a thumbnail so that I can easily select clips for my re-edit.
    I am able to lift the clips and re-position them in the timeline, but it would be much easier if I could get them in the bin as thumbnails.
    I'm teaching myself how to edit and this is for a learnnig exercise.
    Any advice would be most helpful.
    Thanks!
    Windows 7 64 Bit; Avid Media Composer 6.5; Motherboard: Intel DX58SO2; Processor: i7 960 3.20 GHz; Memory: Corsair MX3 6GB 1600 MHz; Video Card: Nvidea... [view my complete system specs]
  • Sat, Jul 6 2013 2:41 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,874
    • Points 24,860
    Re: Is there a way to create movie files from clips?
    You could mark each of the clips and export as a .mov file then reimport them into MC.  That would be one way,  I am sure that others will step in here and suggest others.
    Denny
    Media Composer 2024.12, BCC Continuum 18.0.3, , Asus Proart Z790 Creator Wifi Motherboard with Intel 13700K Processor. 64 gigs DDR5 ram, Windows 10 Pro... [view my complete system specs]
  • Sat, Jul 6 2013 3:46 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 950
    • Points 11,760
    Select each clip and alt-drag it into a bin. This creates  sub clips that you can edit into another sequence.
    1 MC4 Nitris DX on 12 core 2.66 mac pro 6 Gigs of Ram, 2 Symphony Nitris DX on eight core mac pro with 12 gig ram, 3 MC7 on Mac Pro, IMAC, and Macbook... [view my complete system specs]
    WWLD?
  • Sat, Jul 6 2013 10:26 PM In reply to
    • Vampyr
    • Saint Louis
    • Posts 13
    • Points 185
    Thank you Denny, this works great!
    Is there a way to do a batch export so that I don't have to do this for each individual clip?
  • Sat, Jul 6 2013 10:33 PM In reply to
    • Vampyr
    • Saint Louis
    • Posts 13
    • Points 185
    Thank you Brickwad, I'm new to Avid I'm not sure how to drag a clip into a bin.
    When I click on the clip, and alt drag, I see a rectangular lasso and pink marks are placed in the first and last selected clips.
    I tried marking the clips first, but I wasn't able to alt drag to the bin that way either.
    I'm just getting started with Avid, and I'm still trying to learn the basics.
    Thanks!
