Latest post Wed, Apr 23 2014 5:50 PM by Marianna. 20 replies.
  • Sun, Jun 30 2013 11:17 PM
    • JeffWoodward
    • Sherman Oaks, California
    • Posts 144
    • Points 1,765
    ScriptSync and PhraseFind won't install w/ MC 7
    I get a message that says I must install an Avid editing application before I can install these applications. And yet, I have already installed MC 7 w/ Symphony option, and it's up and running.
    Has anyone encountered this problem? If so, any solutions to offer?
    Many thanks!
    Jeff
    MC 2018.12.10; Symphony Option 3.20 gigahertz Intel Core i7 970 Multi-core (6 total) Hyper-threaded (12 total); 7.5 Terabytes Usable Hard Drive Capacity;... [view my complete system specs]
    Jeff Woodward LampLight Pictures Director/Editor
  • Mon, Jul 1 2013 6:31 PM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    Re: ScriptSync and PhraseFind won't install w/ MC 7
    bump
  • Tue, Jul 2 2013 3:32 PM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    Still need the help. Anyone ever experience this? I understand that these apps are supposed to work with MC 7.
    Thanks!
  • Wed, Jul 3 2013 8:03 PM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    bumb (again) [:'(]
  • Wed, Jul 3 2013 9:57 PM In reply to
    Actually, I think that ScriptSync and PhraseFind are part of the full installer since v6.0, and you would just need to activate them in Avid License Control. But this is from memory, let me check.
  • Wed, Jul 3 2013 10:24 PM In reply to
    • Posts 11,457
    • Points 234,105
    Yes that is correct - they activate/deactivate from within the ALC as options.
    Job is spot on - good memory
  • Fri, Jul 5 2013 10:26 PM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    Thanks, Marianna and Job. I still have a problem, however. I did NOT receiver any activation codes for ScriptSync and PhraseFind in the email about the MC 7 upgrade. The codes that are in myaccount on Avid.com are too long to fit in the activation fields in the ALC.
    Is there something I'm missing here?
    Thanks!
    Jeff
  • Fri, Jul 5 2013 10:40 PM In reply to
    • Posts 11,457
    • Points 234,105
    ScriptSync and Phrasefind for use with 5.5 and earlier are 25 digit codes whereas those for use with 6 and higher including 7 are 16 digit.  If you were on 5.5 - you should NOT have deactivatd the options and then when you installed and activated 6.x the activations would have ported over.
    Send me the serial #'s you are attempting to use which are too long.
    marianna
  • Fri, Jul 5 2013 11:12 PM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    Hi, Marianna,
    Email on the way with old codes. I don't have any recollection of deactivating these options when upgrading to version 6, but may have done so inadvertently. Just don't remember anything about that.
    Thanks for your help!
  • Fri, Jul 5 2013 11:19 PM In reply to
    You may or may not have deactivated. In my experience, the auto-generation of PhF and SS license codes simply doesn't always work. But MM will sort you out.
  • Fri, Jul 5 2013 11:36 PM In reply to
    • Posts 11,457
    • Points 234,105
    Jeff
    You have mail :)
    marianna
  • Sat, Jul 6 2013 5:37 AM In reply to
    • JeffWoodward
    • Posts 144
    • Points 1,765
    Hi, Marianna! Thanks for getting me up and running with ScriptSync and PhraseFind. You're always there for us, and I really, really do appreciate what you've done for me today, and what you do for all of us, all the time. You are the face of Avid as far as I'm concerned, and I look forward to the day when I might even meet you in person. You're the best!
  • Sat, Jul 6 2013 4:18 PM In reply to
    • Posts 11,457
    • Points 234,105
    Thanks Jeff!  :)
    marianna
  • Fri, Nov 22 2013 10:47 PM In reply to
    • IBL2010
    • Joined on Sun, Nov 7 2010
    • Posts 11
    • Points 175
    I'm having a simlar problem.
    ScriptSync trial expired and I can't figure out how to buy the new license. Tried ALC but don't have an activation ID to input.
    The Avid store only has ScriptSync for versions prior to MC7. I'm running MC7.0.2
    Please help.
    Thank you.
    Mac Pro 3.32 GHz Quad-Core Intel Xeon Memory: 10GB 1066 Mhz DDR3 Media Composer v. 7 [view my complete system specs]
  • Sat, Nov 23 2013 12:58 AM In reply to
    • Posts 11,457
    • Points 234,105
    Scriptsync comes in 2 versions.   Pre 6 and post 6
    Pre 6 uses a 25 digit serial # to activate whereas post 6 ( 6, 6.5, 7.x ) uses a 16 digit activation ID.
    You cna buy the one on the store and select for MC 7.. and that is the one you need.
    Issues - email me directly
