Since installing 6.5.3 I've been getting intermittent Exception errors while playing trims with rollers on each side of the cut.
The message is Exception: ASpringBuffer: Initialize called with incorrect parameters
It pops up, I click OK I press Play again and it works. It doesn't appear to happen with single side roller trims.
Any ideas what it means?
Dean
I managed to track this down to a configuration issue with my Contour Shuttle Pro and had nothing to do with the 6.5.3 update just a coincidence.
If I trimmed using JKL via my keyboard then played the trmimed cut then all was fine and no ASpringBuffer errors. I recreated the Media Composer config for the Contour Shuttle and it's all working fine now.
