Latest post Tue, May 14 2013 7:24 AM by Nikolaus Beckett Lindberg. 11 replies.
Page 1 of 1 (12 items)
  • Tue, May 7 2013 9:12 PM
    Export to ProTools - Video Mixdown Incompatible
    So I have a project that I want to move over to Pro Tools 10, and I figured I might aswell use the default "Export to ProTools" preset. What could possibly go wrong?
    After exporting I opened the AAF with Pro Tools, and it created a project and brought me to the import via AAF dialouge. On the video track section it said "video not compatible with current session". So I went back to Media Composer, figured I'd just try a different codec for video mixdown. The default was set to "AVC-Intra 100", and after looking up DNxHD it seemed to be the Avid standard. So I tried again with "DNxHD 100". Same result, "video not compatible with current session". Tried googling around for answers on what I might be doing wrong and found nothing. I'm not sure if I'm picking the wrong export settings in Media Composer, or If I'm doing something wrong on the Pro Tools end.
    For referance I am using Media Composer 6.5.2 and Pro Tools 10.3.5
    Asus Z9PE-D8 WS CPU: 2x Intel Xeon E5-2690 RAM: 64GB (8x8GB) G.SKILL Ripjaws X Series DDR3 1866 (PC3 14900) GPU: ASUS GeForce GTX 1070 8GB ROG Strix... [view my complete system specs]
  • Tue, May 7 2013 9:22 PM In reply to
    Re: Export to ProTools - Video Mixdown Incompatible
    AVC-Intra is a rather specific codec. DNxHD should be more compatible, but DNxHD100 is a pretty new flavor. Better use 36/115/145/175/185/220.
  • Tue, May 7 2013 10:12 PM In reply to
    AVC-Intra sounded wierd to me, especially after I looked it up and saw that it was a panasonic codec. Not sure why that was the default setting in the preset.
    Anyways, I tired exporting using DNxHD145 this time and still the same result. Adding some screen caps, incase that helps.
  • Tue, May 7 2013 10:20 PM In reply to
    • Az Kola
    • Joined on Wed, Nov 16 2011
    • London, UK
    • Posts 275
    • Points 3,280
    Can you try a test with DV25 codec
    http://www.flickr.com/photos/azemkola [view my complete system specs]
  • Wed, May 8 2013 12:14 AM In reply to
    Az Kola:
    If it were an option I would. Here are the options I'm given:
  • Wed, May 8 2013 7:49 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    I am guessing your projects is HD at the moment. You need to be on 25i project.
  • Thu, May 9 2013 2:48 AM In reply to
    Yea, it's 720p60. Is that incompatable with Pro Tools? What would I need to change?
  • Thu, May 9 2013 7:22 AM In reply to
    • pt user
    • Joined on Fri, Jul 15 2011
    • Posts 317
    • Points 4,275
    I had a similar issue yesterday - turned out to be AMA related. I thought I had transcoded all my files first (in my case its dnxhd 185x) but I missed a few. I have always found the export to pro tools tab a problem, so I created my own preset. PT10 has no problems playing back Avid Codecs.
    MC8, Hack Mac 12 core SSD, 3x Nvidia Graphics cards Davinci Resolve Macbook Pro i7 quad core , Hitachi Raid drives for Video, ProTools 11, Pro Tools HD... [view my complete system specs]
  • Thu, May 9 2013 10:02 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    720p60 could be one of your issues as PT projects is probably set to 29.97
  • Thu, May 9 2013 12:33 PM In reply to
    • Leo Baker
    • Joined on Wed, Oct 5 2011
    • Posts 494
    • Points 5,805
    I had the same, just go to the Pro Tools LE export from Media Composer and all works fine. I think that issue you are egtting is that it would work with the Pro Tools HD I think.
    MacPro6.1 Late 2013 Intel Xeon 12-Core 2.7GHz 64GB RAM AMD FirePro D700 6GB OSX Mojave 10.14.6. Media Composer 2020.5, Pro Tools Ultimate 2020.5, Avid... [view my complete system specs]
  • Thu, May 9 2013 2:42 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    What  you should be doing. Make sure you are under Project 59.94i on Media Composer and make sure your sequence timecode format is 29.97. Then you are ready do a mixdown or export or create AAF etc.
    Your protools session should be set to 29.97
    This should be working fine
  • Tue, May 14 2013 7:24 AM In reply to
    Well I have no idea why export wasn't working. Forever a mystery, but I did end up finding a solution. File>Send to>Pro Tools works no problem. *shrug*
