Latest post Thu, Mar 7 2013 9:32 PM by FunkyDragon. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Feb 19 2013 7:49 PM
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    Disk Access Denied when writing to XDCam disk
    Normal 0
    I'm having an issue when I go to Output-Export to Device-XDCam I get a "Exception: DISK_ACCESS_DENIED, filename:F:\Clip\C0001.MXF"
    This seems to have popped up after updating the firmware on my PDW-U1 drive.  Here's where it gets strange:  This error happens on two computers running Media Composer 5.0.4...but I was able to get it running on a computer running 5.0.3.
    I am running the Sony XDCam Drive software driver 3.4 after rolling it back from 4.0.1 (after recommended by Sony) and the firmware version of the pdw-u1 is 2.5.4.
    Sony said there's no way to roll back the firmware, so I'm trying to figure out a way to solve this.
    Any suggestions?
    Nick
    Media Composer 7.0.3, Windows 7 Professional, Intel Core i7 950 @ 3.07GHz, 12GB Ram, Nvidia Quadro 2000 [view my complete system specs]
  • Tue, Feb 19 2013 9:26 PM In reply to
    Re: Disk Access Denied when writing to XDCam disk
    Nick:
    Are your permissions for that drive set to "read/write"?
  • Tue, Feb 19 2013 10:00 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    Yes, I believe so.  I went to the xdcam drive utility properties and set the permissions to allow full control along with read and write.
  • Tue, Feb 19 2013 10:33 PM In reply to
    I've seen this kind of error when the clips on the disk are discontiguous, meaning there is a CLIP0001, CLIP0002, CLIP0004, and CLIP0005 - and no CLIP0003.  Avid tries to write CLIP0003, but fails because it can't "insert" that name.  if you rename your clips so that they are in contiguous order, Avid will then be able to properly write (the new) CLIP0004
    you can use your deck or the XDCAM Browser to rename the files on disk, write the new file, and then re-order them again later.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Thu, Feb 21 2013 3:22 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    This is a freshly formatted disk, so not a discontiguous issue.  I've tried formatting in both U1 and a deck, still the error.
  • Thu, Feb 21 2013 4:31 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 81
    • Points 1,025
    Could be silly, but are you trying to export 2 audio tracks ?  I vaguelly remember an issue whereby if you did not have 4 audio tracks, you could not write (export) to the XDCAM.  Shot in the dark.
    MC 8.8.6 on a Z820 Win7/64 48Gb RAM, Black Magic design Decklink Studio 4k... C drive is a Crucial SSD, Internal 6Tb esata (striped 2x3Tb), HP Thunderbolt2... [view my complete system specs]
  • Thu, Feb 21 2013 5:00 PM In reply to
    Just for the record, I'm able to use Export to Device>XDCAM and successfully write to XDCAM disc with only 2 audio tracks.
  • Thu, Feb 21 2013 5:33 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    Yes, I'm trying to write to two audio tracks...
    I spoke with Sony the other day and they had me write to the C drive, and that worked successfully.  I just can't write to the U1 for some reason.  This error repeats on a second computer...and works successfully on a third.
  • Thu, Feb 21 2013 7:54 PM In reply to
    Just a thought: Did Sony have you re-install any drivers on the two computers that do not work, or did you install any drivers on third, working computer?
    I recall from earlier firmware upgrades that Sony included some specifics about power ON/OFF during firmware update.
    Who did you speak with at Sony?
  • Thu, Feb 21 2013 8:05 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    I downgraded the driver to 3.4 to no avail (had to get from sony).  Back to driver 4.01. on the XDCam drive utility software and firmware version 2.5.4.  This is matching the version on the working computer.  I have a feeling its a firmware issue, but there's nothing I can do about that.  I spoke with a couple folks at Sony...specifically Ian.
  • Thu, Feb 21 2013 8:23 PM In reply to
    OK, he's the best.
    Can you re-install anything else, such as a USB driver? Will Utility allow re-running same firmware uodate?
    Will it work withother editing app on same PC?
    What makes the third PC work and the other two not... good luck.
  • Tue, Feb 26 2013 9:32 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    Arg, now I can't import/transcode/consolodate from pdw-u1.  Getting an "Exception:  MXFDomain_INT_FAILED, file:C0001.MXF"
    The computer that the u1 worked is running MC 5.0.3 and the ones that aren't working are running 5.0.4.  Should I try reverting to 5.0.3?
    Nick
  • Thu, Mar 7 2013 5:40 PM In reply to
    • pizzuti
    • Minneapolis, MN
    • Posts 49
    • Points 675
    Just an update...we use Norton Business Suite for our spyware and it went thru an automatic update that locked out our PDW-U1 drive.  Turned it off and now it works!
  • Thu, Mar 7 2013 9:32 PM In reply to
    pizzuti:
    Wow! That's odd... Tthanks for updating the thread, and giving all of us something to look out for!
     The FunkyDragon
    Happy Editing!
