Latest post Mon, Jan 28 2013 4:57 PM by cable. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Nov 1 2012 10:03 PM
    • LW Post
    • Joined on Wed, May 18 2011
    • Posts 44
    • Points 610
    error DISK_TOO_MANY_OPEN
    We seem to keep getting this error on several different computers on our ISIS network. Anybody know what the cause is? Too many disks are open? We're only mounting three volumes -- two for mediafiles, and one for the project.
  • Thu, Nov 1 2012 11:20 PM In reply to
    Re: error DISK_TOO_MANY_OPEN
    I'm going to move this to the Unity Workgroups Forum so our Unity gurus get a look at it.
  • Thu, Nov 8 2012 12:30 AM In reply to
    • LW Post
    • Posts 44
    • Points 610
    Anyone know what this problem even means?
    It happens on any of our computers when they open a long sequence or multigroup clip. Won't play back without beachballing and then reporting this error, or just crashing outright.
    We have lots of different mediafiles folders, could that be it?
  • Fri, Nov 9 2012 5:38 PM In reply to
    • jdw
    • Posts 363
    • Points 4,445
    We have seen this error on a couple clients when on version 6.0.1.  Looking at the console, it would indicate different media each time it errored.  Seems like the issue has gone away since we upgraded to 6.0.3.2.  We are also on ISIS 4.0.
    What versions are you running?
    MC 2018.9 OS 10.13.6 ISIS 7000 (2018.6.1) [view my complete system specs]
  • Mon, Dec 10 2012 10:02 PM In reply to
    • LW Post
    • Posts 44
    • Points 610
    As a quick update, we don't seem to be receiving this error anymore.  Though rather a bit has evolved in our setup since OP, one thing that stands out as a major procedural change is that we've transcoded all our consolidated Canon XF media to Avid 10:1.  We took this step among a few others in order to improve performance for our editors, and ever since the transition was completed this error hasn't shown up.
  • Mon, Jan 21 2013 6:31 PM In reply to
    • cable
    • Joined on Sun, May 27 2007
    • Pacific NW
    • Posts 399
    • Points 5,140
    Did this error ever come back?
    We have been getting this error for about 4 months now and have no idea what to do. All of our MXF media is created using MetaFuze so we are bringing in MXF's and AAF's directly into the Untiy workspaces. We delete the MCState file in the OSX application/Media Composer folder and this gets rid of the issue for a couple of weeks then it comes back.
    Anyone else seeing this?
    Media Network 5.1.3
    All 12 clients via fiber
    All media used is DNxHD36
    OSX 10.7.5
    MC 6.0.3.2
    8 x Media Composer 2020 HP Z4 64GB RAM AJA and Blackmagic Avid Nexis Pro [view my complete system specs]
  • Tue, Jan 22 2013 12:17 AM In reply to
    • LW Post
    • Posts 44
    • Points 610
    Actually, funny you should ask...
    This past Friday, over a month since we last saw it -- we've started seeing it again. Not sure what's causing it.
    It happens on several of our machines... we thought maybe deleting the Project Settings files would do it. That may have been the cure last time, but we're really not sure...
  • Tue, Jan 22 2013 3:05 AM In reply to
    Seeing that you guys having problems are Mac based, see if the DS_Store file in causing it. Solution here. Also, the ._ file might be culprit. For that, you will need a PC connected to the Unity or ISIS to cleanse it.
    MC 2021.3, W10, MSI X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012 Thunderbolt... [view my complete system specs]
  • Mon, Jan 28 2013 4:57 PM In reply to
    • cable
    • Pacific NW
    • Posts 399
    • Points 5,140
    Not too many of our folders on the Unity have any ._ files. Blowing them away doesn't do anything ot help. As a note they are visible with a mac via Terminal. Hopefully anyone doing any troubleshooting on a mac will have Terminal experience. I usually blow them away when I come across them.
    Our lead editor now can't playback a full sequence with getting the DISK_TOO_MANY_OPEN error. This is becoming a show stopper. I'l try Unity support again.
    Thanks.
