Latest post Tue, Feb 19 2013 6:30 PM by Mike Shaw. 224 replies.
Page 10 of 15 (225 items) « First ... < Previous 8 9 10 11 12 Next > ... Last »
  • Wed, Sep 5 2012 7:09 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 693
    • Points 7,810
    Re: MC 6.0.3/SN 6.0.3 bugs.
    Larry Rubin:
    Wim et al:
    Sorry, let me clarify my question. Was the blue line position indicator problem with the motion effect editor present in 6.0.1.1?
    sorry larry, unable to answer that question, and since i installed 6.0.3. from the full installer, can't quickly revert by uninstalling the latest patch...
    symphony 2020.10- win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (456.71 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Thu, Sep 6 2012 4:02 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    dor:
    Ok.. here is another one. This will be a bit hard to explain, but maybe other 6.0.3 users came across this.
    When editing, I am used to press ALT+CTRL+ pointing the mouse to the nearest cut, in order to jump to the last frame of the clip.
    Sometimes, after pressing ALT+CTRL and clicking around the cut, the ALT pressing is getting stuck (All menu first letters are underlined), so if I want to MARK OUT, I get menu command instead, even thou my ALT is not pressed any more.
    I hope I was clear enough.. anyone else?
    Hi
    I just want to report that I have moved back to 6.0.1.1 and this "keyboard+ALT getting stuck" is gone..
    It works normal on 6.0.1.1
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Thu, Sep 6 2012 9:27 PM In reply to
    • daapap
    • Germany
    • Posts 525
    • Points 6,925
    I encounter similar problems at a clients and my own place in 6.0.3:
    All of a sudden "goto next/previous edit>" stops at every edit no matter whether the track is active without alt being pressed. this seems to happen and switch back randomly. Also "replace" sometimes replaces the whole track and not only the active segment, sometime it works on the segment where an in-point is in the timeline instead of the segment under the playhead, sometimes it works like it should.
    In the punch-in tool the source is being shown as "AnalogÉ" no matter whether XLR or RCA is active.
    German Umlaut in bins from 5.5  are being replaced by "Š", "Ÿ" and so."Find" and "sift" do not work anymore accordingly in these bins.
    Marquee produces 110% luma levels. Totally unusable. The screen redraw issues, the pan pot issue, the audio mixer in whole, the tiring grey-in-grey GUI with it's tiny fonts, sluggish responsiveness even on simple tasks although working with fully qualified high end machines with nitris dx - we are fed up with this software.
    After 10 months of never ending trouble my client will now ask Avid to make the software license work with 5.5. Personally i am lucky to have a dongle, but seriously, i'd love to have the money back i spent for the 6.x update...
  • Fri, Sep 7 2012 5:16 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    daapap:
    Hi
    I think there is a special setting for this. "Ignore Track Light" in the timeline setting.
  • Fri, Sep 7 2012 7:29 AM In reply to
    • daapap
    • Germany
    • Posts 525
    • Points 6,925
    dor:
    i know. but pressing "alt" changes the behaviour without changing the setting to "ignore" normally. Now the software behaves as if alt was pressed randomly.
  • Fri, Sep 7 2012 10:02 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    daapap:
    Yes.. strange ALT behaves over here too (as posted above).
    I am back to 6.0.1.1 for now with normal ALT.
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    daapap:
  • Sat, Sep 8 2012 9:31 PM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,430
    It is difficult to know which bugs have been logged or noted before.  Is ther some way we could have a list?
    Export over 1 hour still comes up with an error
    I/O third party MX02 response in effect / colour correction mode is so bad as to be unusable ( I think this is well documented)
    Title tool - thanks for fixing the kerning and cut and paste but it still sometimes fails to save on closing ( at least I can now use cut and paste to save my work into a new title)  Still cant have different size fonts in the same text block as before.
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Sun, Sep 9 2012 2:50 AM In reply to
    Gretski:
    I can't see this here. I mean at Symphony 6.0.3. and MXO2 Mini.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Mon, Sep 10 2012 3:23 PM In reply to
    • Heff
    • Joined on Thu, Nov 5 2009
    • Posts 41
    • Points 495
    I continue to suffer from a littany of bugs in 6.0.3 that were not there in any previous versions, and that are seriously slowing me down.
    1.Random failures to open bins created in 6.01 or 5.5.3 causing " Binary Code" error messages requiring a quit and re-launch,  This is not fixed either by trashing MC state and site settings, or opening the bin again, as previouslt posted here.
    2. When MC is minimised, it releases the AJA IO box, resulting in Bars on the client monitor, not good, as it looks like you're having a problem when you're not!!
    3. AVID Title tool does not display any video when creating a title, and will only display lower track when editing a title, rather than displaying a higher track when toggling "V" as it did in previous versions.
    4. Random failure of centre panning by selecting the pan knob and entering 0. Often need to select the volume slider first. BRING BACK ALT CLICK for Centre Pan!!
    5. No Time-code display of in-point or Durartion when MARK In time is selected in Digital cut tool. This is hightly dangerous when inserting into Masters!!!
    6. No Video displayed when capturuing HDV over firewire in Software only.
    If anyone is having these issues, can they please confirm them here. I believe AVID will only look at them if there are three or more reports.
    Thanks.
    Z620, AJA IoExpress, MC 8.4.5 [view my complete system specs]
  • Mon, Sep 10 2012 9:27 PM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 129
    • Points 1,375
    RajK:
    MC engineering is looking into Marquee generating illegal whites and black issue, this will be addressed in the next patch.
    Does Marquee 6.0.3 turn legal colors into illegal ones, or does it only fail to turn illegal colors into legal ones?
    In other words, if I only use gray 16 through gray 235 when I build a title in Marquee, will Marquee alter my grays so they go outside that range?
    Core i7 930 PC 2.8GHz / 18GB RAM / Win10 Pro 64bit / nVidia Quadro K2200 (driver 411.95) / MC 2018.12.9 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Tue, Sep 11 2012 2:48 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    We do have the same DV capture errror:
    aborted because audio attempted to overun its buffers !
    Are there a work around this problem?
    Or do we have to downgrade to 6.0.1 ?
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Tue, Sep 11 2012 3:54 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Allan:
    Any external hardware, if so, could you try with that one disabled - disconnected .
    If not, going down to 6,01,1 might be a solution, as said in another thread I suspect this new toggle off command to cause this
    Tomas
  • Tue, Sep 11 2012 6:31 PM In reply to
    Another still not repaired bug: The subclip indicator in the capture tool still gets corrupted when capturing subclips. The subclip number overites the film symbol and is illegible. This started with 6.0 and is stll present with 6.03. Anybody out there with 6.5 see this?
    System 1: HP Z400, 3.20G Quad Core, Quadro 4000, 250G SSD system drive,Windows 7 64, MojoDX w/active hib, 6G ram, Cal Digit VR ESATA Raid, Recommended... [view my complete system specs]
  • Wed, Sep 12 2012 7:16 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,427
    • Points 15,690
    Not here in the foreground thread with no errors 6.0.1. Lately, I have noticed that very often when you turn off the MC, remains occupied RAM Avid Bin Indexer and need to shoot down it manually in Task Manager.
    V.
    AVID MC2020.10, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 442.50, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
