Latest post Fri, Mar 9 2012 3:52 PM by Aliocha. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Mar 5 2012 8:20 AM
    • Aliocha
    • Joined on Sat, Dec 4 2010
    • paris
    • Posts 13
    • Points 135
    avid 6.0.1+matrox mini m02+mbox mini
    Hey everybody,
    first i apologize if this topic has ever been seen, but i was not able to find any solution.
    So, After quite some difficulties to activate avid, then phrasefind, the keybord language issue, my last problem is that avid doesn't see my mbox mini. That's a real problem for me, i need to put some voice over my edits. The mbox works fine in windows, it's regognized without any issue, but in avid, i only have the matrox hardware and the 1394. No mbox. I have installed the mbox mini driver 1.0.6, firmware 0.7.0
    What am i missing? It would not be the first time  i'm blind, but any helps will be really appreciated.
    Have good day all avid users
    Alexis
    Imac pro 2017 2,3GHz intel xeon w 18 128 Go 2666 MHz DDR4 Radeon Pro Vega 64 16 Go Blackmagic extreme 3 Catalina 10.15.7 Avid 2020.9 [view my complete system specs]
  • Mon, Mar 5 2012 9:19 AM In reply to
    • Zoppito
    • Stuttgart - Germany
    • Posts 209
    • Points 2,920
    Re: avid 6.0.1+matrox mini m02+mbox mini
    No solution but even Avid recognizes the mbox, you will not be able to perform a voice over. Voice overs are only working in 1394-mode with disabled mbox.
    AVID Version 7.0 HP Z800 Win7 (64bit) 48 GB RAM Nvidia Quadro 4000 Matrox Mini [view my complete system specs]
  • Mon, Mar 5 2012 9:27 AM In reply to
    • Zoppito
    • Posts 209
    • Points 2,920
    Have you installed the correct mxo-drivers for the current AVID version?
    After installing the drivers you should shut down your machine and "power-off" the mbox for a few seconds.
  • Mon, Mar 5 2012 4:10 PM In reply to
    • MikePoglitsch
    • Naperville, IL
    • Posts 183
    • Points 2,425
    http://community.avid.com/forums/t/103230.aspx?PageIndex=1
    11+ pages of comments on this issue.
    2 Avids: Z400 Win 7 - 12GB RAM, BlackMagic Intensity Pro, z400 Win 7 Matrox MXO2 Mini 12GB RAM Both trying to run MC 7, QT 7.7.4 Acclaim Media... [view my complete system specs]
  • Mon, Mar 5 2012 5:17 PM In reply to
    • Aliocha
    • paris
    • Posts 13
    • Points 135
    Hello,
    myu problem is not the matrox but the mbox. So i did not read all the eleven pages of problem, but not sure i'm concerned. Bad luck for me!
  • Mon, Mar 5 2012 5:26 PM In reply to
    • Aliocha
    • paris
    • Posts 13
    • Points 135
    Thank you for the answer,
    the only driver given whith the install of avid 6 are fore the mbox2, the mbox pro, the mbox 3g or the digi002 and 003, nothing for my mbox 3 mini. I have only install the driver 1.0.1 from the digidesign website. I cic not find any other driver. I bought this mbox 6 montes ago, i can't believe it cannot work with avid 6. Butt sometimes the truth is unbelievable... But I still think it should work...
    Concerning the matrox mx02, if i unplug it, i still don't have the mbox in avid.
    alexis
  • Tue, Mar 6 2012 7:12 AM In reply to
    • Zoppito
    • Posts 209
    • Points 2,920
    Go there:
    http://www.matrox.com/video/en/support/downloads/
  • Tue, Mar 6 2012 7:43 AM In reply to
    • Aliocha
    • paris
    • Posts 13
    • Points 135
    Hello
    i'm a little confused, i have no problem with my matrox mini mx02, i have installed the latest driver whan i have updated avid to 6.0
    The only issue i have is with the mbox mini. It works perfectly in windows, but not in avid...
  • Tue, Mar 6 2012 11:48 AM In reply to
    • Zoppito
    • Posts 209
    • Points 2,920
    sorry, i`ve misunderstood your posting :-) - the mbox only works with mxo disabled. If you disable the mxo you can see the mbox in your audio settings and you can perform a voice over
  • Fri, Mar 9 2012 3:52 PM In reply to
    • Aliocha
    • paris
    • Posts 13
    • Points 135
    Unfortunatelly that's the point, Even if I disable the Matrox mx02, I can't see my MBOX...
    And obviously, It seems that Nobody has the same issue...
    Anyway, thank you
