Latest post Wed, Nov 20 2013 9:49 PM by Roger Shufflebottom. 270 replies.
Page 1 of 19 (271 items) 1 2 3 4 5 Next > ... Last »
  • Wed, Feb 8 2012 12:23 AM
    MC on Mac 6.0.1 Bugs
    I'm establishing and pinning this thread as a one stop location to report bugs on the Mac version of MC 6.0.1. Please keep your reports as short and concise as possible. Thank you for your cooperation.
  • Wed, Feb 8 2012 3:10 AM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,800
    Re: MC on Mac 6.0.1 Bugs
    "Expand Luma Range" for full screen playback on a computer monitor has not been fixed. The setting toggle makes no difference. On the plus side, horizontal tearing does seem to have been fixed.
    (Symphony 6.0.1 software only / Mac 10.7.3)
    - Oliver
  • Wed, Feb 8 2012 4:37 AM In reply to
    Export Fails
    With MC6.0 one hr exports would fail using the Matrox h.264 1080i60 codec within 5 min. of completion with a message saying that "fast start" creation was in progress even though I had disabled that option in the export preset.  I would need to force quit MC to exit.
    With 6.0.1, the 60 min. export fails at the same spot, but now an error message appears.
    Exception: std::exception, what:"Segmentation fault" in thread "CQTExportWorkingThreadBody", at address 0x0
    So far exports of the exact same material of 30 seconds and 30 minutes complete successfully.
    I have found others complaining of the same "fast start" lockup with 6.0 using other codecs.
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
  • Wed, Feb 8 2012 5:08 AM In reply to
    When using the MX02 mini the audio meters are not in sync with the video.
    Media Composer 6.0.1, Mac Pro 8 core 2.66, 16gb RAM, Nvidia geforce 120, Lion 10.7.2 [view my complete system specs]
  • Wed, Feb 8 2012 7:04 AM In reply to
    I'm still seeing horizontal tearing.... not a deal breaker, but annoying.
    MC|Software - Symphony 8.4.3, Win 8.1 Pro 64 HP ZBook 17, 32GB RAM, Quadro K5100M 8GB, Dreamcolor, Aja IO Express [view my complete system specs]
  • Wed, Feb 8 2012 10:47 AM In reply to
    Trimming - good news - the monitors update correctly when dragging rollers and using JKL. Bad news - the green light monitor indicators do not swap from side to side with the mouse prior to dual-roller trimming. They only activate correctly AFTER starting the trim. This was broken in 6.0 and needs addressing please.
    iMac i5 27", 40GB RAM, OS 10.14.6 with MC 2021.9 with Symphony option, BlackMagic mini monitor. 2020 MacBook Air with MC 2021.6 ... and NewsCutter... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
  • Wed, Feb 8 2012 2:56 PM In reply to
    • pt user
    • Joined on Fri, Jul 15 2011
    • Posts 317
    • Points 4,275
    blank quicktime ref outputs with 6.0.1.....
    Just installed 6.0.1 after uninstalling 6.0 - My quicktime refs are blank when viewed in qucktime player. They are created using Avid Codecs. Is it possible the codecs are no longer installed? I cant recall if I had to download them separately. I did notice that the 6.0.1 dmg is nearly 50mb smaller than its precdecessor. Any ideas????
    looks like im going back to 6.0.0 ....
    MC8, Hack Mac 12 core SSD, 3x Nvidia Graphics cards Davinci Resolve Macbook Pro i7 quad core , Hitachi Raid drives for Video, ProTools 11, Pro Tools HD... [view my complete system specs]
  • Wed, Feb 8 2012 6:54 PM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 269
    • Points 3,560
    Re: blank quicktime ref outputs with 6.0.1.....
    Full Screen Playback Issues:
    - Expand Luminance On Computer Displays option doesn't work
    - Horizontal tearing in FSP
    - When a Matrox MXO2 mini (and probably any other monitoring solution) is connected, FSP isn't available anymore. This did work in previous versions. This issue has been raised months ago and should really be fixed. I'm certain I'm not the only one that works with FSP on a second HD computer monitor, and a LCD client TV connected to the MXO. With MC 6.0 I can't have an image on the second monitor and the client TV at the same time, unless I use some workaround with component cables.
    Symphony 2019.6 on Mac Pro Westmere 3.33Ghz 6 core, 48Gb Ram, Nvidia GTX 980, High Sierra 10.13.6, BMD Ultra Monitor 2019.6 on MacBook Pro Retina 2018... [view my complete system specs]
  • Thu, Feb 9 2012 2:27 AM In reply to
    • Jose Bucaro
    • Joined on Fri, Jan 29 2010
    • San Jose, CA
    • Posts 42
    • Points 555
    Trim to the right 1 frame and trim to the right 10 frames keyboard buttons do not work on the keyboard.
    If I use the following steps: Tools AudioSuite and I asign a filter (example: Compressor/Limiter Dyn 3) when you hit the preview button nothing happens it only says processing.
    MacPro OS Lion 10.7.2 2 x 2.4 Ghz Quad-Core Intel Xeon 26 Gb 1066 Mhz DDR3 (2) CalDigit VR [view my complete system specs]
  • Thu, Feb 9 2012 2:32 AM In reply to
    • Jose Bucaro
    • San Jose, CA
    • Posts 42
    • Points 555
    Also forgot to mention that playback still not smooth, it stutters. I Do not have this issue with 5.5
  • Thu, Feb 9 2012 3:13 AM In reply to
    • Jose Bucaro
    • San Jose, CA
    • Posts 42
    • Points 555
    During multicam editing system froze and I got the following message: SFPlayConsumer::Excecute TIMEOUT
  • Thu, Feb 9 2012 8:42 AM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 269
    • Points 3,560
    MXO2 MINI issues
    - Playback stutters, skipping a frame once in a while
    - Sluggish, less responsive feeling than software-only MC
    - Matrox 3.0 drivers
  • Thu, Feb 9 2012 8:49 AM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 269
    • Points 3,560
    AUDIO MIXER
    - it's not possible to snap the panning values using the alt button anymore
    - The Audio Mixer window look nice but it's way too big. It takes 2/3 of a 1080p screen when expanded to 16 tracks. At least make it resizable, or provide a less detailed Audio Mixer as an option
  • Thu, Feb 9 2012 9:10 AM In reply to
    • Euchrow
    • Brussels, Belgium
    • Posts 269
    • Points 3,560
    FULL SCREEN PLAYBACK (cont.)
    - Everytime I trim a frame, the FSP jumps to black for an instant. Quite annoying
  • Thu, Feb 9 2012 2:03 PM In reply to
    This isn't a bug.... it's a coding change.  ALT click snaps the pan to the "project setting" now.  So if your project is all tracks centered, it will center.  But if your project is all tracks L/R... it will snap to L or R.  Click on the desired track, hit the 0 key and then hit enter... this is the quickest way to Rome now.
    Euchrow:
    2020 iMac Retina 5K-8-Core/i7/96 GB RAM, Avid DNxID, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
