somewhere in these forums i read that it exists, and thus i can use metafuze to get dnxHD proxies of arriRAW into my mc5.
there was a dead link to arri's site at the same spot, but a search on arri site or via google does not bring it up.
or - is it baked in on the current metafuze 2.5?
have we found downloadable sample clips of arriRaw footage somewhere on the web so that i could test the workflow before the d-day?
I haven't used MF with ArriRAW, but I'm fairly certain you don't need a plugin for it.
*edit* you do. http://archiv.arri.de/arriraw/index.html.
You need the Arri plug in for MetaFuze which used to be available in the partners section of Arri's website. Maybe try to contact them directly.
Etienne AllardEngineer | P&S Creative ProfessionalAvid
thanks for the heads-up. will try that.
still - wouldn't it be in everyone's interest that this be either included in metafuze or made available at avid's downloads section?
and just to double-check - once i got the plug-in i'll get correct LUT for log-c > dnxHD 709 transcoding?
You should be able to generate the appropriate LUT from Arri's website.
http://www.arri.de/camera/digital_cameras/tools/lut_generator.html
MetaFuze supports the following LUT formats:
If you plan to export the media to DS, you can use the following 3D LUT formats:
But how to apply it in MF?!
