This is a SD issue only - I'm having no problems with HD.
In any Standard Definition project (720X480 NTSC) created on my MC4 I can output the timeline via firewire through my DV recorder/player and watch the show on a SD television and everything looks perfect.
I can record the timeline on DV tape, import it into my old computer in Xpress pPo, make a DVD in Sonic DVDit and it looks perfect.
However! I cannot make a DVD using the Avid DVD by Sonic in my current computer. Any DVD I make jitters all over the place as if there is a field order problem. (HD projects look perfect on DVD and Blu-ray)
To compound the problem, I cannot tell if the Sorenson Squeeze files are the problem because Avid DVD insists that what should be compliant squeezed files are not and happily trancodes them again.
So, if I import a QT reference file into Avid DVD and let the program transcode it I get crap. I changed the field order for the QT reference file in Avid DVD (top instead of bottom) and it looks the same. I changed the mode to progressive and it looks the same.
The original video is fine. The timeline in MC4 is fine. The firewire output is fine. My old Sonic DVDit makes perfect DVDs. The problem is somewhere between MC and Avid DVD or in Avid DVD, but I can't figure where it is.
I need to get dozens of football DVDs out to a client this weekend and the thought of having to transfer everything via tape to my old, slow computer to make master DVDs is very depressing.
So I tried to author a DVD on Adobe Encore, (which I forgot I had.) Same problem. Tried upper field, lower filed and progressive. Bottom line, my MC4 does not export usable QT reference files in SD. It jitters all over the place in any DVD authoring program I try. And since I have no field options - or much or anything else - exporting QT reference, I'm dead in the water.
It's going to be a long weekend.
I'd so tests but not with QT refs. Your not actually changingt he content with a QT ref so it's not very helpful.
I'd export as section as a QT file and force the field order on export with both upper and lower and test with those.
Broadcast & Post Production Consultant / Trainer Avid Certified Instructor VET
Thanks for the reply, Pat, but you're making my point. The QT reference doesn't work. To have to make QT files of hour long football games and then transcode it takes a long time. I can't figure out why my old, clunky computer with XpressPro and DVDit can do it effortlessly (although very slowly) with a QT reference file while my new MC and Avid DVD haven't a clue.
Sometime around the MC4, a change of codecs and procedures that fugovali in XPress Pro had to be reworked. Specifically, the AVID DV PAL codec was changed field order. But I do not know if there is a change to NTSC. William
I changed the field order in my trancode tests. Upper, lower and progressive. It made no difference in Avid DVD or Encore. Neither program could resolve the issue. Whatever is coming out of MC as a QT reference file is not usable in any workarounds I can find.
Have you got some 720 by 486 shots mixed with the 720 by 480? I recall seeing posts about this causing similar problems with NTSC DVD's some years back.
I wish it was that easy, Andrew. This is one, uncut shot taken of a HS football game. No cuts. Just a title card made in Avid. No stray, off-sized shots.
You may need to do a video mix down before you send it out a QT REF. I had a similiar problem with jittery frames and this resolved it.
Mark In/Out and select the video tracks you want to include in the Mixdown and then go to Special>Video Mixdown.
David, thaks for the advice. Didn't work. Making a mixdown also defeats the purpose of QT reference. I might as well take the time and memory to make a QT movie, which works.
Okay, someone explain this to me. More problems trying to make a simple SD DVD! At a business I freelance for we had major computer problems with their editing computer. After many blue screens I finally managed to make a QT movie of a show cut on MC5 and sent the computer off to have Windows reinstalled.
I get home and decide to put the QT movie into DVDit in my old computer as that's currently the only way i can make a DVD that won't stutter (see above posts). I make a Sorenson Squeezed file and a DVD and it jumps - plays along and then jumps a few frames forward, picture only, the sound is fine. No picture stutter or banding, just these jumps every few seconds. This is the exactly the same problem I had trying to make a DVD on the computer at the above mentioned editing house. I'm really pulling my hair out because the QT movie plays fine on its own.
In deperation, I load the QT movie into my old XpressPro, send the resulting timeline out as QT reference, squeeze the file and make a DVD. It plays perfect!
Can someone explain to me why both MC4 and MC5 seem incapable of producing a file that creates usable DVD in Avid DVD? Considering two different computers with two different MCs produce exactly the same miserable results, something is wrong here. I ask again, why can my clunky old XpressPro make perfect files and perfect DVDs when the other systems can't.
UPDATE - I finally managed to make a good DVD in Adobe Encore by making sure the field order is the same (bottom first). Changing the field order in Avid DVD slightly improved the stuttering, but it was still there and unacceptable - better in lower first, but still bad. Same situation in my home studio computer and in the computer at work. At this point I think Avid DVD is just plain junk in SD situations.
I some time get same kind of problem. let me tell you what workrd for me. First remember to mix down the video and the audio of the last sequence on time line.Then send it to Avid DVD as quicktime reference. I hope you have done this. The surprizing thing is the DVDmade by AVID DVD some times do not play on all machines.what i experimented is just to copy the DVD using Roxio and then use the copy. it works . I do not know why this happens!
it may help you to fix the case, cheers
Not that this helps, but I just made a DVD using Avid DVD 6.4.4 and MC 5.5.3 and it worked perfect. I used a QT Ref NOT a Sorenson endcode. Avid DVD does NOT like encoded material at all and will re-encode it. I should also point out that is was HD material that was transcoded by Avid DVD to SD.
Check that your using the correct QT for your specific version of Avid.
Beyond that maybe a complete re-install would help.
I realize this is an old thread and happened to stumple upon it searching for something else (haven't figured out the logic why it referenced this thread though) but I had the same problem a while back and solved it by making sure NOT to use the Avid codec with a QT ref. It seems using the Avid codec fudges up the field order plus also leaves it at 720x486. Without the Avid codec it's 720x480 as it should be and also no field order issues whatsoever.
Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
