Latest post Wed, Apr 11 2012 11:55 AM by JonnyL. 7 replies.
  • Sun, Dec 4 2011 8:35 AM
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 125
    • Points 1,680
    Region Stabilize - auto zoom.
    Hello,
    Auto Zoom in Region Stabilize effect is not working.
    Zb.
    HP Z8 G4, 2xXeon-6246R, 128 GB RAM, Win 10 Ultimate, MC 2020.10, Nvidia Quadro RTX 4000, Boris Red 5.6, BCC 14.0, Saphire 11.0.2 Adobe CC, TMPGenc [view my complete system specs]
  • Mon, Dec 5 2011 8:35 AM In reply to
    Re: Region Stabilize - auto zoom.
    could you give some details what you have done?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Tue, Dec 6 2011 2:22 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,421
    • Points 97,440
    It works for me in 5.5.3, and I'm pretty sure that it did in 5.5.2.  As Hans said, some details of your workflow might help.
  • Tue, Dec 20 2011 5:02 PM In reply to
    • B. Kaulfuss
    • Germany
    • Posts 11
    • Points 195
    It is the same here in version 6.0. I drag the region stabilizer on to the clip in the timeline, but if select the button auto zoom on this has no effect. This seems to be a bug in Avid FX 6.02.
    Greetings from Germany
    Intel I7 930 2.8 GHz, Windows 7 Professional 64 Bit 12 Gig Ram, Geoforce 285 GT, System HD 1 Gig, 3-Hard disks Samsung 3,5 TB Raid 5, Asus VW246 HDMI... [view my complete system specs]
  • Tue, Dec 20 2011 5:53 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    B. Kaulfuss:
    You need to clarify if you are seeing this with the Region Stabilize effect in MC 6 or from inside of Avid FX 6 when having done a stabilizing, both of those effects needs a tracker to be used initially, have you done that
    edited ...  just remembered that the tracker in the Avid Region Stabilize filter is running when rendering afterwards, better to use the ordinary Avid Stabilizer, gives you more control
    Tomas
  • Wed, Feb 22 2012 3:45 PM In reply to
    • ZFigas
    • Poland
    • Posts 125
    • Points 1,680
    Hello,
    I am sorry but I was absent and I can send more information about problem, today.
    The first situation - Auto zoom in Stabilize Region effect is not working.
    http://screencast.com/t/mDNYqwBxVf8
    The second situation - when I want to open timeline where are added Region Stabilize effect My MC 6 show me communicate that is fault in line 654 and I must to click Continue so many how many is effect on Timeline in window.
    If I use another places in my sequences and will be Rgion Stabilize effect situation is same.
    http://screencast.com/t/mRQbSePF3IW5
    Greetings from Poland
    Zb.
  • Fri, Apr 6 2012 10:18 PM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 129
    • Points 1,375
    I am seeing probably the same problem here.  Using MC 6.0.1 Windows, I applied a Region Stabilize effect in a 1080p23.976 project, Model=Translational, with Auto Zoom and Progressive Source both checked.  After rendering, it turns out that the image has actually zoomed in, BUT it is cropped incorrectly, so that a black margin creeps into the shot.
    It worked fine in MC 5.5.
    Ken
    Core i7 930 PC 2.8GHz / 18GB RAM / Win10 Pro 64bit / nVidia Quadro K2200 (driver 411.95) / MC 2018.12.9 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Wed, Apr 11 2012 11:55 AM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,430
    Yes I have the same problems - Auto zoom not working in region stabilise and Pan and zoom going from 5 to 6 does not work
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
