Latest post Thu, Jun 21 2012 12:58 AM by Ken Lent. 61 replies.
Page 3 of 5 (62 items) < Previous 1 2 3 4 5 Next >
  • Tue, Dec 20 2011 6:03 PM In reply to
    • CColton
    • Joined on Sun, Jul 17 2011
    • Posts 218
    • Points 2,730
    Re: Batch Import of AVCHD Fails in MC6
    Do they want files to play with? Like examples of files that fail to import, or the media that MC creates and leaves in the Creating directory?
    Freelance producer/editor/videographer, Colton Media Productions
    Specs: Avid Qualified HP EliteBook 8760w |
    MC6.5 | Intel i7-2640M CPU @ 2.8 GHz | 8 GB RAM | NVIDIA Quadra 3000M | Windows 7 Pro | Software-only, I have no Avid hardware. | After Effects CS4 | Nuke 6.3
  • Tue, Dec 20 2011 6:15 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    CColton:
    The things that are of most importance from how I see it, is if there are differences between the ama linking and the transcoding of the same clips.
    What ama links well should also transcode well, if that isn´t the fact those files might be of interest if they are plain camera files and not manipulated in any way of course.
    Tomas
  • Tue, Dec 20 2011 6:32 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    The files operate normally in traditional import (as opposed to batch import) and they link and transcode through AMA without a problem. No single AVCHD file has successfully batch imported, though. It seems to be an AVCHD-wide problem, not specific to any file.
  • Sat, Dec 24 2011 6:05 AM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    Ok everyone, time for some more creative troubleshooting. The import/relink workaround that we established earlier is no longer working, so I can't change the resolution on clips any more. Help!
  • Mon, May 14 2012 9:49 AM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 129
    • Points 1,375
    Has there been any progress on fixing this six-month-old bug?
    The import/relink workaround worked for me on one clip, but MC refused to relink on a second clip, so I had to re-edit everything using that clip.  In light of that failure, I can't trust the workaround to help rather than hurt.  So now I will have to finish my project in DNx36.
    Avid, please fix this bug!
    Core i7 930 PC 2.8GHz / 18GB RAM / Win10 Pro 64bit / nVidia Quadro K2200 (driver 411.95) / MC 2018.12.9 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Mon, May 14 2012 10:51 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Ken Lent:
    Could you please explain what it is that isn´t working for you and what workflow you are using
    Tomas
  • Mon, May 14 2012 12:44 PM In reply to
    • Feralfons
    • Galicia, spain
    • Posts 119
    • Points 1,330
    Fix in 6.0.1.1
    check with new patch
    MC2018 SymphonyOption, BMD 4K Extreme, Dual XEON 14 core, 128GB Ram, Titan X Pascal, Stardom SAS Raid5 // Artist Color // MC2018 SymphonyOption on MacbookPro... [view my complete system specs]
    Fernando Alfonsin
    www.alfonsindigitallab.com
  • Mon, May 14 2012 2:42 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    Refresh my memory on where to find and download the patch? I have 6.0.1 and batch import still doesn't work; I'm crossing my fingers for 6.0.1.1.
  • Mon, May 14 2012 3:03 PM In reply to
    • Posts 11,457
    • Points 234,105
    Go to https://www.avid.com/US/account/orientation
    Log in to your master account or if you dont have one create one on the left side of the screen.  On the next page access your Download center account or if you do not have one requet one on the left side of the screen.
    6.0.1.1 is located inside the Avid Editor Patch Folder
    PC - you must install 6.0.1 first then run the 6.0.1.1 patch over it
    Mac - you must remove 6.0.1 and install 6.0.1.1 Mac as it is a full installer
    marianna
  • Mon, May 14 2012 3:12 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    Marianna:
    marianna
    Thank you! Once I've installed it, I'll let you know if batch import works again for me.
  • Mon, May 14 2012 4:02 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    The problem has been resolved in the MC 6.0.1.1 patch! Woohoo.
  • Mon, May 14 2012 4:26 PM In reply to
    • Posts 11,457
    • Points 234,105
    WHHHHHHHHHOOOOOOOOOOOOOOOOOO HOOOOOOOOOOOOOOOO
  • Mon, May 14 2012 4:35 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    Marianna:
    I think the forums need to borrow the "like" feature from Facebook so that I can like that post, haha.
  • Thu, May 17 2012 2:17 AM In reply to
    • Ken Lent
    • California
    • Posts 129
    • Points 1,375
    Thank you everyone for jumping in on this one, and glad to hear that Batch Import is working again in 6.0.1.1 for some of you!
    I installed the 6.0.1.1 patch and tried Batch Import on a long (44 minutes) master clip.  The first time, MC crashed toward the end of the task.  The second time, it logged an error message in the console, but I unfortunately lost the message.
    I am up to my ears in some projects right now, but I will retest and post the console message when I can take a break.  (Probably not this week.)
    Meanwhile, has anyone had success in 6.0.1.1 with Batch Import on long clips?
    Ken
  • Thu, May 17 2012 10:46 PM In reply to
    • CColton
    • Posts 218
    • Points 2,730
    I'll try a long one when I get a chance but honestly I don't have time at the moment. Overnight some night this week, perhaps.
