Hi all.
I am working on a project that we move bins back and forth to other editors and producers. 99% of the time it works flawlessly. But this week the following has happened twice now, on different sequences.
Reality show, multicam, with grouped audio on each track. For example 10 contestants, 10 mics, if you right click on an audio clip, you get to see all 10 microphones and you can flick between them. Each contestant is named and numbered. Works great. However what has suddenly happened, on the entire sequence, every single audio clip has become the same person, the same microphone. If I right click on it now, it shows every 10 audios, but they now are all the same person? on every single clip in the sequence. If I match back it takes me to the original group clip and the group clip audio is fine. The only solution I can see is to MANUALLY re edit every single audio clip.
So this did not happen while I was editing. This happened as I opened the bin, received from my producer. Avid somehow is losing the link. Why 99 percent of the time does this work fine and then randomly this happens now?
Producer is on a slightly older version of Avid, and I am on 2022.4
Anyone else ever seen this?
I JUST WORKED IT OUT!!!!
I had one piece of offline media now, and I tried to relink the sequence... and all the grouped audio once again linked to the same microphone.
© Copyright 2011 Avid Technology, Inc. Terms of Use | Privacy Policy | Site Map | Find a Reseller
