Latest post Fri, Jul 4 2008 12:29 PM by editzz01. 88 replies.
Page 1 of 6 (89 items) 1 2 3 4 5 Next > ... Last »
Sort Posts: Previous Next
  • Tue, Jul 1 2008 6:41 PM
    • MovieMaker76
    • Top 500 Contributor
    • Joined on Tue, Mar 25 2008
    • Los Angeles
    • Posts 166
    • Points 2,160
    Up all night / Fits of rage / Crypto shell extension? / .cat file / security catalog??
    OH MY GOSH!!!!
    One problem leads to another and to another....
    ok, I was setting up this raid 0 array in my computer.
    Long story - short.
    I wiped out one of my hard drives.  NOW, I have files I needed on there - so I bought (69.99) software Easeus - to recover the files.
    It did.
    But now, I can't open any of them - they say "this file is invalid for the following: security catalog?  I can't open these .cat files.  I have tries some downloads - but they have failed.
    Seriously my friends, I have been up all night / have had fitsSuper Angry.
    Help me please.
    Intel Core 2 Duo E 6700, RAID(0), NVIDIA Quadro FX 3450/4000, 4GB ram, Vista64, MC 3.0 [view my complete system specs]
  • Tue, Jul 1 2008 8:29 PM In reply to
    • BLKDOG
    • Top 10 Contributor
    • Joined on Thu, Oct 13 2005
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
    • Moderator: Avid Xpress DV Mac
      Moderator: Avid Xpress Pro Mac
      Moderator: MCA Mac
    Re: Up all night / Fits of rage / Crypto shell extension? / .cat file / security catalog??
    Drive recovery is a 50/50 proposition. If you absolutely have stuff on there that is irretrievable, you may want to send the drive to a recovery service but, as Obi Wan once said to Luke "You'll have to sell your speeder...."
    Symphony Nitris DX Mac Pro Dual 3.0 4 gigs of Ram [view my complete system specs]
    Do you really want to know what's wrong...or do you just want me to fix it?
    FCP2Avid
  • Tue, Jul 1 2008 8:33 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    But it recovered the files.  I saw them as they were recovered - mxf files.  But, now they are all in this .cat name - There has to be a way to open them.
  • Tue, Jul 1 2008 8:44 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    That's the problem with the MXF wrapper. IF it gets damaged, it's kinda tough to rebuild. Is the media such that you can't recapture?
    FCP2Avid
  • Tue, Jul 1 2008 8:48 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    There has to be a simple exlanation.  It is not just the mxf files, i cannot open anything.  So there must be some kind of  way to open them.
  • Tue, Jul 1 2008 8:54 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Well all I can tel you is that I've had two occasions to try disc recovery software. The first went pretty well, lost a few files but got most back. The second was a disaster. lost everything. Files were created but could not open them.
    If ya find a way, let us know.
    FCP2Avid
  • Tue, Jul 1 2008 9:00 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    yes, i can recapture, but, I have editied the project for about 20 hours now.  It was almost done.
  • Tue, Jul 1 2008 9:02 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    So recapturing won't affect your cut.....As long as you still have your sequence, batch capture either the clips or the sequence itself and it will all be back.
    FCP2Avid
  • Tue, Jul 1 2008 9:07 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    I do have the sequence still.  But, how will it know how to pull the files / where to pull the files.
  • Tue, Jul 1 2008 9:09 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Ah the Magic that is Avid...from what sources did your media come?
    FCP2Avid
  • Tue, Jul 1 2008 9:10 PM In reply to
    • vpcmike
    • Top 50 Contributor
    • Baltimore, MD
    • Posts 957
    • Points 11,335
    I am not familiar with the program that you used to recover the files, but I have had great success with R-Studio in the past - it is easy to use and everything that it managed to see it was able to recover without issue.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Tue, Jul 1 2008 9:22 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    I had them all on an internal drive.  But, I wiped the drive out - by prematurely formatting it.  But, I saved the sequence on my external drive.
    So, should I capture to a certain drive?
  • Tue, Jul 1 2008 9:25 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    O no, you had QT files on that drive too?
    Do you not have backups of the movies?
    Two things I always do...have at least one backup of my source material and never put that source material and my media files on the same drive.
    FCP2Avid
  • Tue, Jul 1 2008 9:29 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 166
    • Points 2,160
    no, all my media is gone.
    just says media offline when i enter the project.  but the timeline and sequence is intact.  my bins all have the names but w/ out media
  • Tue, Jul 1 2008 9:33 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Understood but that media had to come from someplace......
    and I'm taking from you that the Movies you imported to create that media were on the same drive? Were they no where else?
    FCP2Avid
