Tips & Tutorials
Deko & Clip AutoUpdate Utility
Published on: Thu, Oct 8 2009
ClipAutoUpdate is a free Avid Deko utility that monitors a specified clip folder on the E drive for new clips that are added to the folder and automatically transcodes any new clips added to the folder to use in Deko and imports the clips automatically to the designated clips database. ClipAutoUpdate.exe is an executable program and is located in the C:\Dekoxxxx\Utilities folder.
For ClipAutoUpdate to operate it must be launched and configured to actively watch a folder for any changes to the folder. If it is launched after files have already been added to the folder, it will not import those already existing files.
To start ClipAutoUpdate.exe launch it from the Utilities folder and configure it to monitor a clip folder and update a specified clip database with changes to the folder. (Navigate to C:\Dekoxxxx\Utilities and double-click ClipAutoUpdate.exe to launch the program.)
clip_image002
Deko supports two types of clip databases: Standard clips and Power Clips. Standard clips are full screen, or full resolution, clips. Power Clips (Deko3000 only) are smaller-sized clips, such as ‘moving headshots.’ Power Clips are contained in a database separate from the Standard clip database (Select View > Clip Editor > Context > Type. Both types of databases can be monitored with ClipAutoUpdate. AutoClipWatch can be configured to watch separate folders for Standard Clips and Power Clips (both must be housed on the E drive) and will update separate databases with changes to each of the folders. It can also be configured to monitor for additions of specific file formats (i.e. *.dv, *.mov, etc.) and import to the appropriate database only if these file formats are encountered.
Power Clips Note: PowerClips retain the *.mov file format and are not transcoded into *.mxf files.
ClipAutoUpdate automatically adds a clip to the Deko clip database using the filename’s base as the database item name. Since Deko uses separate files for video fill and video key, a suffix is added to the basename as ‘_v’ for video fill and as ‘_k’ for key (i.e. matte, fill). For example, a blue.mov file that has an embedded key will import into Deko as blue_v.mxf and blue_k.mxf.
Note: Since ClipAutoUpdate uses the base filename for the database entry, two clips with the same name cannot be inserted into the database (i.e. Filename.dv and Filename.mov do not import as two distinct files).
View Complete Thread
