Problem: I imported an ALE (Avid Log Exchange) and want to link them to some imported files, that are placed in one folder. I try to batch import all my clips from that one folder, but can only do one file at a time. Is there a way for Avid to batch import multiple clips, so I don't have to manually import every file?
Solution: The answer is Yes. After importing your ALE into your bin, check your master clip names (under the Name Column) so it matches letter-for-letter the actual file you are trying to import. It must be matched, even to the file extension (e.g. .jpg .mov). As long as: 1. The master clip names match the original source file names 2. And the original source files are located in one directory (as opposed to multiple folders) Doing the batch-import of one file should automatically link all other files, in that directory , without having to manually link each file, one by one. If the ALE file you imported does not have the file extensions, you will need to re-create that ALE to include the file extenstions at the end of each master clip name. Depending on the circumstances, a copy and paste procedure of the file extension to each clip name, could make this process faster. ALE files are commonly created using Microsoft Excel.
To watch a demonstration of this, please click on the movie below:
Understand the amazing benefits of uploading an industry tip or tutorial. Click the link below to start receiving benefits!
Upload tip & tutorial
Avid Technology, Inc. brands: Digidesign | M-Audio | Sibelius | Pinnacle Systems | Sundance Digital
© Copyright 2000-2008 Avid Technology, Inc. All Rights Reserved — Legal Notices | Terms of Use | Privacy Policy | RSS Feeds | Site Map
