Latest post Tue, Aug 23 2011 1:46 AM by Bokes. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Aug 19 2011 2:23 PM
    • Bokes
    • Posts 219
    • Points 3,205
    Transcode grayed out?
    I am running the trial version on a MacAir as a test. I'm curious to see if the New MacAir's can handle some simple location edits.
    I imported a small 5D clip. I am trying to transcode the clip to DNxHD 145 MXF and the transcode button is grayed out...?
    It's been awhile since i've used Avid- but what am I missing here? How can I transode the file?
  • Fri, Aug 19 2011 3:02 PM In reply to
    • Posts 10,925
    • Points 227,365
    Re: Transcode grayed out?
    HI there Bokes...
    Go to page 459 of the following guide....
    http://cdn.pinnaclesys.com/SupportFiles/attach/Media_Composer_Editing_Guide_v5.5.pdf
    Make sure AMA is on.
  • Fri, Aug 19 2011 3:05 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    more info- I notice in Transcode my system drive does not show up. I assume this is the reason the file will not transcode.
    On my Macpro all my drives- including the system drive show up as options and I am able to Transcode to the the system disc.
    Back on the Mac Air- In Media Creation setting all drives filtered out is selected and grayed out as well...?
  • Fri, Aug 19 2011 3:18 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    Thanks Marianna
    yes- AMA is on.
    I am following the guide.
    I think the issue is my target drive is NOT showing up in the video/Data box.
    How do i fix that and make it happen?
  • Fri, Aug 19 2011 3:28 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    more info- just tried to perform a simple import and Avid tells me there is no media drive available.
    So now I'm convinced this is the issue.
    I know I am able to use the system drive as a media drive on my Mac pro....why not the laptop?
    Again- this is just a test. Ultimately- I will hook up a Thunderbolt Drve.
  • Fri, Aug 19 2011 11:28 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,536
    • Points 64,255
      Moderator: MCA Mac
    Are you running Lion?  Are you running MC 5.5.3?
  • Sun, Aug 21 2011 2:03 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    Yes- Lion and the latest Avid trial version 5.5.3
  • Mon, Aug 22 2011 2:53 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    Still can not get this to work on the lap top....I have used all the suggestions here.
    Anything else?
  • Mon, Aug 22 2011 3:45 PM In reply to
    What are the permissions on your boot drive?  You may need to open them up...
  • Tue, Aug 23 2011 1:46 AM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    That was it!
    Thank you sir. I'm using a fresh, out of the box MacAir and forgot to make that setting.
    BTW- So far- 5.5.3 runs surprisingly smooth on the Mac Air off the system drive. 2 streams with PIP and color effect- play down fine. Scubs like butter. Very impressed. Now I just need to add a TB external and send the interface to an 27inch external.
    I am still getting screen tear- but I give up on that. I've seen it in every version going back to 4.something.
