Latest post Wed, Jul 20 2011 12:50 PM by udosauer. 2 replies.
  • Wed, Jul 20 2011 9:25 AM
    • Coralee
    • Joined on Tue, May 24 2011
    • Cape Town, South Africa
    • Posts 77
    • Points 1,095
    Avid Quicktime Compression
    Hi there,
    I have a question regarding exporting "uncompressed" quicktimes with Avid MC5.5.2.
    If a client requests an uncompressed quicktime, when exporting, by the "compression type", is it better to select "None" or rather "Avid Meridien Uncompressed" or "Avid 1:1 x" ?
    Similarly, with Quicktime Pro 7, would one export using the compression type "none" or "uncompressed 4:2:2" ?
    Thanks guys!
    2x MC 5.5.3 Windows 7 Pro 64-bit Intel Core i7-2600 CPU 3.40 GHz 8GB RAM NVIDIA GeForce GTX570 & GTX460 1TB SATA 3 6Gb/s HDD 42" LED monitor via... [view my complete system specs]
  • Wed, Jul 20 2011 9:51 AM In reply to
    Re: Avid Quicktime Compression
    If you use any Avid Codec the client should install the Avid Codecs at his/her machine.
    However I don't want to see the file's size if it will be uncompressed.
    Desktop PC
    3 Heads Digital Films
  • Wed, Jul 20 2011 12:50 PM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 448
    • Points 5,255
    Hello,
    If you use "none" the file contains uncompressed 8bit RGB values. If you use the avid uncompressed codec you get Y'CbCr values with 4:2:2 subsampling. And the bad thing is that quicktime internaly converts to rgb before converting to   Y'CbCr. So whenever you can try to use "export same as source" then you'll get a streamcopy of the codec used in your timeline. (If you have mixed codecs do a videomixdown before exporting).
    regards,
    Udo
    2x HP Z800 with Mojo DX and MC7.0 | 1x HP Z800 with Nitris DX and MC7.0+SYM-Option | 1x Unity MEFC5 [view my complete system specs]
