Latest post Thu, Jul 7 2011 9:14 PM by konx. 3 replies.
  • Wed, Jul 6 2011 8:50 PM
    • konx
    • Joined on Mon, Dec 13 2010
    • Zurich
    • Posts 10
    • Points 130
    Sudden System Crash
    Hi there,
    I need you're great help once again! (It's such a great forum!)
    I'm working as assistant editor. The project was shot on RED, transcoded after AMA-import to DNxHD36.
    Now: suddenly our Avid Media Composer starts to make a lot of problems. He crashes all the time with eighter the following error message "Bus error" in thread "MainThread", at address 0x0 or "segmentation fault" in thread "MainThread", at address 0x0 or without any message. And he does it a lot: yesterday about every 15 minutes! I tried a lot: I deinstalled Final Cut Pro from the system, I changed all firewire cables, I copied the whole project (all the bins) into a new avid project... Nothing stopped Avid so far from crashing from time to time... Copying into a new project first seemed to work: he didn't crash for about 10 hours. But the pleasure was not ment to last: he crashed again two times the last 2 hours.
    The specifics of the editing system:
    Avid Media Composer 5.5.1
    Mac Pro, OS X 10.6.8, 2x2.66 GHz 6-Core Intel Xenon, 20GB Ram 1333MHz DDR3
    Harddrives: 3x WD MyBook Studio Edition 1TB, Firewire 800
    Thanks for all suggestions!
    All the best from Switzerland!
  • Thu, Jul 7 2011 1:50 AM In reply to
    • Posts 10,204
    • Points 218,070
    Re: Sudden System Crash
    Hi knox....
    First things first...... MC 5.5.1 isnt approved for use pn OS 10.6.8.
    MC 5.5.1 is approved for use on OS 10.6.6
    MC 5.5.2 is approved for use on OS 10.6.6 and 10.6.7
    Thats the first issue......
    Secondly... what graphics card do you have?
    Lastly, what is attached to the CPU?  Matrox, AJA, Nitris, Mojo.... some of these wont work when connected and have been known to cause this.
  • Thu, Jul 7 2011 2:26 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    And while you're at it launch the Apple Disk Utility and do a Repair Permissions on your drive(s).
  • Thu, Jul 7 2011 9:14 PM In reply to
    • konx
    • Zurich
    • Posts 10
    • Points 130
    thanks for your suggestions both of you.
    @Marianna: i know, that's true. but i did work on an other project on an other station with the same OS and also 5.5.1 without any troubles. maybe that was just luck back then... the more i make research on my problem, the more i guess it's all about our mojo-box which is connected to the mac via firewire 400... luckily we didn't have a crash since yesterday...
    @hbrock: i will do that the next time i'm in the editing room. thanks for that!
