hey fellas,
does anyone else of you noticed a unsteady video output thru the matrox mxo2mini?when i scroll thru my timeline in edit mode everything works fine, but when i go to color correction mode and scroll thru my timeline the matrox just outputs a frame all 15 frames. (like it uses to be when you work with really slow harddrives and scroll in the timeline)
and more, when i klick between the windows current, reference and previous it often doesn´t output the highlighted picture.
i noticed that on a couple different avid systems with matrox mxo2mini included. would be great to get this fixed if this is fixable?
cheers sven
www.svenbudelmann.comhttp://www.imdb.com/name/nm0118967/
Hi Sven
System specs, driver versions and application versions ??
Tomas
at the moment:mc 5.0.3.9os x 10.6.6matrox driver 2.1.1.0050
noticed that effect also in prior patches. not sure if i tested mc 5.5 already.... did you?
I am currently on 5.52 and 2.2.3 without seeing this but I have also used the combo you are desrcribing with the exception for that it might have been 5.0.3.5.
I have never had problems with playing in realtime, where are your media stored ?
external via e-sata.as i said its working fine in the source rec editing timeline.its like the matrox cant´t interpret the blue line position when in color correction mode. its not just this system where i´m at the moment. i noticed that at least on 4 different avid configurations with the matrox box attached.
don´t get me wrong. i love the matrox mxo2 mini more than all other harware combis cos i can use it with an eizo foris via hdmi. and the best: with the configuration u ahven´t got any processing delay. like you would have with an sdi connected monitor (JVC-DTxx e.g.)s
HI Sven, I am not able to repro this, have you tried with creating a new workspace
a new day. at the moment everything is working properly. it may have to do with a restart. thats probably why i got the feeling that it became worse near the end of the day.is this a memory thing?
also really long sequences seem to work with hundreds of color effects and 10 tracks audio waveforms switched on. weird. i´ll see how the day develops.
Yes, sort of " should work " , I am one of those that have helped Matrox doing tests with this but as patches comes and goes and new drivers are released rather frequent it´s somehow difficult to cover it all, the combinations drivers - patches are quite many.
Avid Technology, Inc. brands: M-Audio | Sibelius | Pinnacle Systems |
