Latest post Fri, May 20 2011 2:24 PM by jwrl. 6 replies.
Page 1 of 1 (7 items)
  • Thu, May 19 2011 12:16 PM
    • edi
    • Posts 51
    • Points 610
    Best way to convert 1080/25p to 24p (24 fps)
    Hi everyone
    I have a film that was shot HDcam 1080/25p , and finished on symphony nitris at 1:1 HD 25 fps,
    and was handled at 25 fps all the way, including sound.
    However, we are making a DCP version that is 24 fps.
    The sound designer wants a Quick Time DV-PAL version of the film in 24 fps in order to check that the speed change matches ok an in sync. Video quality in not the issue, just something decent to work with.
    Whats the best way? I went with Modify the sequence to 24p, opening a new 24p project, open the modified sequence, render and export.
    I'm not completly sure it worked, and maybe not the best way to go. What do you say?
    Any thoughts will be greatly appreciated
    Best
    Edi
    Dell Inspiron 5110 Intel i7-2630QM 2.0, 8 GB ram, Nvidia Geforce GT 525m, Win7 Premium 64 bit, MC 5.5.3 [view my complete system specs]
  • Thu, May 19 2011 9:25 PM In reply to
    Re: Best way to convert 1080/25p to 24p (24 fps)
    edi:
    That will not generate the right conversion.
    You need to physically lower the speed of the clip. You can manually change the framerate of a QT file, using CinemaTools or Dumpster. See this thread, for instance.
  • Fri, May 20 2011 6:04 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,393
    • Points 97,070
    Job ter Burg:
    You can also lower the speed by exporting a QTref of your master from your 25 fps project.
    Create a 24 fps project and open the console.  Type "ignoreQTrate 1" and press enter.  Close the console and import your QTref file.
    You should now have a 24 fps timestretched version of your 25 fps master.  Export that for your sound team.
  • Fri, May 20 2011 6:27 AM In reply to
    • edi
    • Posts 51
    • Points 610
    Thanks very much for the help. I'll try it out...
  • Fri, May 20 2011 8:19 AM In reply to
    Jwrl's method is a great one too. Just make sure your source file has no sound, otherwise IgnoreQTRate won't work. Here's some more info about 24-25 framerate changes.
  • Fri, May 20 2011 1:59 PM In reply to
    • edi
    • Posts 51
    • Points 610
    Success!!
    Thanks guys, your the best.
    Actually, I thought it didn't work, but the remark on the "no sound" saved the day.
    I also tried the image sequence method that is mentioned in the PDF Job attached,
    and it works just the same, but the export takes longer, so...
    Anyway, awsome to have the help from you..
    Cheers
    Edi
  • Fri, May 20 2011 2:24 PM In reply to
    • jwrl
    • Posts 8,393
    • Points 97,070
    Job ter Burg:
    Yeah, sorry, forgot all about that.  Whenever I've done this a separate pitch-shifted 24 fps sound layup is used.  Accordingly I've never exported the sound from the 25 fps project.
    Thanks, Job.
