Latest post Mon, Oct 29 2012 6:38 PM by jbrad2orr. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Mon, Mar 14 2011 10:38 AM
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    aja io express
    Is anyone using this little box yet?
    How does MC fair with it? Does it work as it should? Any pitfalls?
    It's the one carrot of 5.51 that I like the sound of!
    3x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 8.9.2, 2x Aja IO, 1x Blackmagic 4k Studio 16TB T-Box Shared Storage with 8gb Fibre connection... [view my complete system specs]
  • Mon, Mar 14 2011 12:35 PM In reply to
    Re: aja io express
    Please! Someone must be using it?
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Mon, Mar 14 2011 3:16 PM In reply to
    Re: aja io express
    We just got ours hooked up last week.
    If you are using a Desktop, make sure you buy the one that is PCIE and not the one for laptop use.
    Works great. Easy to set up.
    Check out the blog on our site to learn a bit more about our experience as we had trouble at first and had to adjust our deck to get digitizing to work proper.
    http://bit.ly/AvidAJA
    The Deck control on it does not work with avid so you'll need to get a control cable from someplace like www.Adenda.com.
    and don't worry about sending it reference, that doesn't work either. But the signal looks great for a great price.
    Follow me at www.twitter.com/redarrowryan Avid 1- z400 6-Core, with Nitris DX Symphony 6.0.3 Win 7 64 Bit [view my complete system specs]
  • Mon, Mar 14 2011 4:02 PM In reply to
    Re: aja io express
    Thanks Mr. Difficult.
  • Mon, Mar 14 2011 4:20 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    Thanks. Good blog about issues too. Nice to know its been well tested!!
  • Thu, Mar 31 2011 4:22 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    Mr Difficult, I've managed to get hold of a demo box to try. Output wise, all working ok via hdmi at the moment, but trying capturing im getting various different pop ups.
    Could you help confirma couple of settings for me.
    In the capture tool, does it display hdsdi or does it just give sdi or hdmi as the options for video?
    It lets me capture hd via sdi if I play the deck first then mark my in/out. Batch then also works. Not sure if its related to a reference issue, as sometimes get a hdsdi audio clock error. Currently feeding a composite video signal as ref to test which is working for now.
    Currently capturing of hdv deck via hdsdi
    Ant
  • Thu, Mar 31 2011 5:20 PM In reply to
    Re: aja io express
    In the capture tool, the video input only says HDMI and SDI not HDSDI, even though we are in an HD project.  But feeding it an HDSDI signal seems to work for us and it captures fine.
    When we talked to Avid and AJA support, they said that the ref in on the AJA did not work with avid, so I don't think your test is going to give better results. (we also tried two different black burst generators that had no affect).
    We haven't not gotten the HDSDI audio clock error you mention, but we are using a Sony HDcam deck for capturing.
    good luck and let me know how it turns out.
  • Thu, Mar 31 2011 6:25 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    Have you left the reference set to internal then?
    Do you set the audio in capture tool to be hdsdi?
    I'll have a proper play tomorrow, I've had it capturing some clips, but not consistantly and the moment!
    If I can sort this out, it will be a fantastic bit of kit!!
  • Thu, Mar 31 2011 8:34 PM In reply to
    Re: aja io express
    I thought IO express was output only on PC side. Are you guys using it to capture HDSDI within MC 5.5? And if so it works at all HD frame rates?
    System 1: HP Z400, 3.20G Quad Core, Quadro 4000, 250G SSD system drive,Windows 7 64, MojoDX w/active hib, 6G ram, Cal Digit VR ESATA Raid, Recommended... [view my complete system specs]
  • Fri, Apr 1 2011 11:59 AM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    The IO Express is a capture box for mc5.51. It uses SD-SDI,HD-SDI,HDMI for capture and monitoring.
    I'll post again shortly with where im at with testing.
  • Fri, Apr 1 2011 12:35 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,194
    • Points 61,025
    Re: aja io express
    Just a thought: is the Aja card sitting in the proper slot as per Avid config guidelines?
    MC 2018.2, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Apr 1 2011 1:41 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    OK this is where I'm at.
    Kit used:
    System. xw8400 dual core 2.67, win7 pro 8gb ram mc5.51 qt7.6.9 nvidia fx1500 v190.38
    Unity 5.1.3 and 5.3 client
    Aja io express in pci-e x16 slot
    Also SDI mojo connected to system but switched off
    Monitoring using lcd via hdmi and crt via sdi
    VTR - HVR1500 HDV deck using either sdi or hdsdi outputs
    remote via rs232 addenda on com port
    audio out io express monitor outs into sonflex redbox converter into ppms then speakers
    HDV1080/50i material on tape and some already imported xdcam 35mbps footage
    In a SD project: Connecting SDI
    Batch capture and Capture tool via sd-sdi works perfectly. Seems frame accurate, plays back smoothly, with no issues, or errors. All in-sync and io express outputs an sdi signal to my crt and a sd signal via the hdmi to the lcd. Audio levels are hot coming out of io express into soniflex redbox convertor, but just need to adjust dials to tweek down, so not worried about that for now.
    In a HD project: Connecting HD-SDI
    capture tool - without a tape running, I get an error "hd-sdi source not connected...." as soon as I play the tape I dont get the error anymore. It then lets me capture or log clips fine. I've sometimes had the error pop up when exiting from the capture tool. Batch capture works fine.
    Since installing QT7.6.9 this afternoon playback has seemded fine, all in-sync.
    Beforehand was running QT7.6.8 and was having random errors "legend audio communications error..." and "streamingplayconsumer:execute pass timeout" error. Either of these errors could pop up in random places. Where the timeline would stop you could play that clip with no issues, or even go back a few seconds and play straight past where the cursor stopped! So there seemed no reason for it to stop. There was also no coloured lines saying any drive/cpu/frame issues etc.
    Yesterday as I posted above I was getting some occasional errors to do with hd-sdi audio clock. This hasnt happened today. Not sure if it was to do with the aja settings.
    I know the xw8400 isnt suported for the aja, but windows 7 was supported either, but myself and many others have it working.
  • Fri, Apr 1 2011 1:57 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    My aja capture settings
  • Fri, Apr 1 2011 2:01 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 309
    • Points 3,900
    Re: aja io express
    my aja playback settings
  • Fri, Apr 1 2011 5:01 PM In reply to
    Re: aja io express
    I know with my Mojo DX if there is no signal coming in and the capture tool is the focus you'll get the HD-SDi source not connected error, and also the streamingplayconsumer error. Seems like capture, when in capture on the fly mode needs a constant video source or it has issues after 10 or so seconds if it is the focus.
