Latest post Fri, Apr 21 2017 1:29 PM by mattess. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Feb 8 2011 6:11 AM
    Top and Tail commands delete everything from that point
    As an Avid newby (coming from another popular NLE) I find the Top and Tail commands in MC5 extremely useful to quickly trim a sequence.  However, on certain sequences the Top command deletes everything in the timeline left of the position indicator, and the Tail command deletes everything right of the position indicator.  This is occurring on a project in which I lost media due to a RAID failure, forcing me to re-import the files.  It does not occur on a fresh project.  All other commands seem to work fine.  What could be happening?
    Michael
    Media Composer 2018.4 w/Symphony | OS X 10.13.4 | iMac 2017 (Retina 5K, 27-inch, 2017) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB external... [view my complete system specs]
  • Tue, Feb 8 2011 9:19 AM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 462
    • Points 5,590
    Re: Top and Tail commands delete everything from that point
    Hi Michael,
    top/tail trim is related to the selection of your audio- and videotracks. So if you have only one long audioclip but 4 shorter videoclips, MC will trim to the end of the long audioclip with head/tail trim, including trimming the 4 videoclips.
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Tue, Feb 8 2011 3:05 PM In reply to
    Kristina:
    That makes sense.  However, my situation is much simpler.  It's just a string-out with one video track and two synced audio tracks.  The cuts are all straight.  No J or L cuts.  If there are 50 clips to the right of the position indicator, for example, the Tail command selects all 50 and makes the cut at the position indicator, leaving nothing after that point.
    Michael
  • Tue, Feb 8 2011 3:14 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,315
    • Points 17,010
    Are all tracks selected when you make your top/tail trim? You must select only the track you want to trim. Remember, in Avid the empty timeline is treated as black leader and will be trimmed too if those tracks are selected.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.12.2, MC 8.8.2 [view my complete system specs]
  • Tue, Feb 8 2011 4:07 PM In reply to
    conleec:
    That's it.  These sequences have an almost empty video track that I use for the occasional cutaway, and that track was also selected.  When I deselect it, Top and Tail works as it should on the selected tracks.  Thanks for pointing this out.
    Michael
  • Fri, Apr 21 2017 1:29 PM In reply to
    • mattess
    • Joined on Wed, Dec 10 2014
    • Posts 13
    • Points 105
    Hi there,
    is it also possible to delete only the head or the tail of a clip without rippling (with top and tail trim button)?
    Thanks in advance!
    Cheers,
    Matthias
