Latest post Wed, Feb 9 2011 5:38 AM by hbrock. 16 replies.
  • Thu, Feb 3 2011 11:17 AM
    • thegrifter
    • Joined on Thu, Feb 3 2011
    • Posts 5
    • Points 55
    Upgrade from Media Composer dongle to dongle free
    Hi
    First time poster.
    I am trying to upgrade from version 3 with a dongle to version 5 without the dongle.
    I rang the European support number but they require a code in order to talk to someone!
    There is no documentation that I can find from moving from a dongle to no dongle, the documentation
    that accompanies the software upgrade talks about flashing the dongle to update it to use with version 5.
    But I do not want to use this dongle.
    Can anybody point me in the right direction on how this can be achieved..
    It is for a new Install on a new Macbook Pro 17" , Running 10.6
  • Thu, Feb 3 2011 11:35 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,723
    • Points 226,270
      Moderator: MCA Mac
    Re: UPGRADE FROM MEDIA COMPOSER DONGLE TO DONGLE FREE
    Just plug in your Dongle and, after you launch the sofware, choose to use the software activation option. Your system will activate and your dongle will be deactivated.
  • Thu, Feb 3 2011 12:06 PM In reply to
    • thegrifter
    • Posts 5
    • Points 55
    Ive installed the software
    Which option do I use
    I want to activate my software using internet
    I want to activate by phone
    I want to activate my software using my dongle
    I want to activate using my companys licensing cert
  • Thu, Feb 3 2011 12:13 PM In reply to
    • thegrifter
    • Posts 5
    • Points 55
    I have added the dongle in and booted the system and clicked software Licensing
    It noe asks for my system ID and serial number, however you cannot use numbers when trying to input the code..
  • Thu, Feb 3 2011 4:51 PM In reply to
    • thegrifter
    • Posts 5
    • Points 55
    anyone else can help?
    You cannot use Numercial numbers when up putting in sys ID serials..
    So Im stuck.
  • Thu, Feb 3 2011 5:01 PM In reply to
    Call European support and select option 2 for help with dongle/software activation problems.  The call is free.
    ciao,
    Carl
    Media Composer 2018.4 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT 740M [view my complete system specs]
  • Thu, Feb 3 2011 5:07 PM In reply to
    • thegrifter
    • Posts 5
    • Points 55
    Hi Carl
    Tried all day but it says you need a support code number
  • Thu, Feb 3 2011 5:16 PM In reply to
    Hi
    I just gave it a try (using + 31 20 654 5530) and they're closed, so I couldn't try it out to see what's wrong with it.  They'll be open again at 0900 Central European Time.
    If you're desperate you could call the US office at +1 800 800 2843 and select option 2 and then option 2 again for software activation help.  I just tried and was able to get through without a support code.
    I'm afraid that's the best we can do on the forum, as we're all just editors who volunteer to help out here.  You might also contact Todd (BLKDOG) who answered before; he works for Avid and is good at sorting out this kind of thing.
    ciao,
    Carl
  • Tue, Feb 8 2011 7:00 PM In reply to
    • Duncan
    • Joined on Fri, Feb 15 2008
    • Posts 22
    • Points 285
    thegrifter...
    Hi, just wondered what the outcome with this was!
    BTW, by not using the dongle, does that mean you can run AMC in 64bit?
    Mac Pro 3.33GHz 6-Core Intel Xeon "Westmere", 12 GB memory. Avid Xpress Pro v.5.6.3 [view my complete system specs]
  • Tue, Feb 8 2011 7:03 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,723
    • Points 226,270
      Moderator: MCA Mac
    No. the software is a 32 bit application no matter how you run it.
  • Tue, Feb 8 2011 7:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,723
    • Points 226,270
      Moderator: MCA Mac
    Also, the serial number does not have numerical characters in it. It is different from your system ID and should be printed on the inside cover of your getting started guide manual if you recieved one.
  • Tue, Feb 8 2011 9:39 PM In reply to
    • Duncan
    • Posts 22
    • Points 285
    Hi BLKDOG.
    Simce you work for Avid i hope you don't mind me asking some questions:
    1) Why is Avid still 32bit?
    2) Is a 64bit version in development?
    3) If i run AMC on a Mac Pro, do i have to switch the Mac to 32bit for AMC to work, or do i leave the Mac in its default 64bit and AMC will simply use only 32bit of it (sorry if that's a dumb question, but i'm just a humble editor Confused  )
    Big thanks if you can answer those (thanks anyway if u can't Smile)
  • Tue, Feb 8 2011 9:54 PM In reply to
    Hi Duncan,
    Duncan:
    BLKDOG will probably be along soon, but just in case, I thought I'd answer, too.  First, though, you should know that asking a question (or three) that is totally unrelated to the original topic of the thread is called "hijacking" and it's considered somewhat rude.
    In the future, if you want to ask a specific person a specific question, I'd suggest using the "Contact" button on one of their posts.
    Now, on to your questions.
    1. Not sure how to answer this.  It's still 32 bit because it's not 64 bit yet.
    2. Speculating about the future of Avid products is prohibited by the Terms of Use you agreed to when you signed up.  Asking about the future development of Avid products isn't necessarily speculating, but it's close, and at any rate Avid doesn't often say what they're planning for the future.  The short answer is, "Nobody knows and we're not supposed to ask."
    3. One of the Mac guys will have to handle this one.
    ciao,
    Carl
  • Tue, Feb 8 2011 11:14 PM In reply to
    • Duncan
    • Posts 22
    • Points 285
    Hi camoscato. Thanks for the heads up on the T&C, didn't intend to be rude. What made me think of the 64/32bit issue was that i read somewhere that it was because of the dongle that MC had to run in 32bit. No idea if that's true. As you said, maybe BLKDOG, or one of the other mac guys can answer. Hopefully thegrifter will be interested, apologies if not.
  • Tue, Feb 8 2011 11:16 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,449
    • Points 63,180
      Moderator: MCA Mac
    When you start up your Mac using the 32-bit kernel, 64-bit apps will still run as 64-bit.  Conversely, when you start up in 64-bit, some 32-bit apps won't work.
