Latest post Thu, Feb 3 2011 9:35 AM by Alain Yahchouchi. 3 replies.
  • Tue, Feb 1 2011 9:00 AM
    audiosuite not opening
    hi, i have a problem
    usually i dnt use a lot the audiosuite, yesterday it opened but took 1 min for the plugins to load,...
    hgowever today when opening the audio suite window the wholw avid appi is freezing and not responding, on audio suite is 92%  i waited one 1 hr and last ended the api (ctrl alt delete).  restarted the api and same problem?
    whats wrong?
  • Tue, Feb 1 2011 11:04 AM In reply to
    Re: audiosuite not opening
    Hard to say without knowing your system specs... But you could try to reinstall Avid, in case Audio Suite did run at all on your system. Be sure to backup your project files before reinstalling. In case you installed any 3rd party audio plugins, get them off your system and try again, without or with reinstall.
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
  • Tue, Feb 1 2011 11:19 AM In reply to
    how to backup?
    thx
  • Thu, Feb 3 2011 9:35 AM In reply to
    Hello,
    good news: today i tried opening the audiosuite and it opened!
    I want to shorten an audio track, it is 2secs, i applied a time shift plugin from audiosuite and when previwing hearing the correct effect that i want. however after rendering, in the timeline the audio track is still 2 secs, and the effect is split, it shld be of new duration of 4secs while when previewing. i tried to trim to elongate but didnt work? whats the solution?
    thx
