Latest post Mon, Jun 16 2008 3:11 AM by tikboy. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Feb 7 2006 6:07 PM
    • yankeet
    • Posts 37
    • Points 505
    consolidate doesn't work on all files
    I'm trying to consolidate but when I load only media files or precomputes, some are left on the original drive and are not moved to the new drive.
    I tried manually moving one such file and it worked, so I know it's not a share (locked file) issue.
    another issue I get with consolidation is an occasional error of
    Exception: RGBADescriptor::CalcPixelEidth() - Unsupporeted pixel eidth., width:18
    anyone knows what to do?
    Yankee
  • Wed, Feb 8 2006 3:37 PM In reply to
    • yankeet
    • Posts 37
    • Points 505
    Re: consolidate doesn't work on all files
    Maybe someone from Avid knows why this happens?
  • Tue, Jun 3 2008 7:20 AM In reply to
    • tikboy
    • Posts 247
    • Points 2,910
    HI,
    I want to bump this one...I'm having the same issue.
    Thanks.
    Intel Core2 Quad | 4 G RAM | WinXP Pro, SP2 | Avid XP Studio Essential (5.2.1.2910) - Internal SATA hard drives - G-Raid firewire/usb drive - Mobile hard... [view my complete system specs]
  • Tue, Jun 3 2008 9:28 AM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 443
    • Points 5,365
    can you give me details of which version are you all running and what storage you have etc Yes
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Tue, Jun 3 2008 9:29 AM In reply to
    • Blue Crow
    • Posts 443
    • Points 5,365
     The pixel width can relate to effects but I'm not so sure that it is the case here.
  • Fri, Jun 13 2008 9:07 AM In reply to
    • tikboy
    • Posts 247
    • Points 2,910
    Thanks for responding.
    Hope these info helps:
    • - Avid XP Studio Essential (5.2.1.2910)
    • - Internal SATA hard drives
    • - G-Raid firewire/usb drive (we swap with a 2nd Avid system)
    • - Swappable hard drive rack/tray system
  • Fri, Jun 13 2008 4:59 PM In reply to
    • Vidiot Tech
    • Joined on Thu, Apr 6 2006
    • South Carolina
    • Posts 90
    • Points 1,050
    yankeet:
    I get this one too...
    Xpress Pro 5.7.2, Internal SATA drives, external firewire 400 drives
    System Specs: Dell M90, 4GB Ram (3GB Avid Enabled), nVidia FX 1500 w/ driver 8.4.2.9, MC 2.8, QT 7.2, External WD 750 GB eSata Drive [view my complete system specs]
    Steve Godsey, CLVS
    "No, I do not have attention deficit issues, just – Oh, look! There goes a rabbit!"
  • Fri, Jun 13 2008 5:39 PM In reply to
    I have seen this. At least in our experience this occurs when you consolidate files created from a different version of the software or a corrupt render.
    Only workaround I know is to find the offending file (Divide and Conquer) and delete or export a standalone OMF file.
  • Sat, Jun 14 2008 12:17 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    My money goes to a corrupt file as well... are there (by any chance) media files that come from previous projects or consolidations?
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, Jun 16 2008 3:11 AM In reply to
    • tikboy
    • Posts 247
    • Points 2,910
    I'm afraid that's it.
    Yes, we're sharing this project with a different version of AvidXPs. I'm working on a different project right now but I will try your suggestions.
    Thank you.
