Latest post Thu, Dec 16 2010 5:50 PM by Kevin Klimek. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Dec 15 2010 12:27 AM
    • mjc
    • Los Angeles, CA
    • Posts 146
    • Points 1,745
    AMA and Working with Stills
    Is there any way to have the Avid honor import settings when linking to ama still files?
    I have a boatload of images that I'd like to link to (as opposed to importing) which will be serving as reference files for animations being created.
    I know I can import them all, but that takes a lot more time and uses up space.  The AMA linking works really well for images that are at smaller than 1920x1080, but anything bigger crops out the image.
    Thanks.
    Nitris DX Symphony Option / MC 7.0.4 | Mac OS X 10.8.5, Dual 3.2 GHz Quad-Core Intel Xeon MacPro, 10GB RAM | Facilis Terrablock 24D [view my complete system specs]
  • Wed, Dec 15 2010 5:32 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,355
    Re: AMA and Working with Stills
    Interesting use of Ama linking of stills, I can see both ups and downs with it.
    After that you have placed your clips on your sequense and maybe made a rough cut, add the Avid P & Z or ( better ) BCC P & Z if you have it, to all clips and relink to the origin stills, will give you correct aspects for all stills, even large ones.
    Tomas
  • Wed, Dec 15 2010 3:22 PM In reply to
    Check the "reformat" column in the bin.  You should be able to change it to a setting shows the entire image (although it may have a letterbox or side bars).
    This only works in the bin; any clips you have in the sequence don't change.  (You have to re-edit them in.)  But future edits will include the change.
  • Wed, Dec 15 2010 3:38 PM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,043
    • Points 12,980
    Kevin Klimek:
    Can't you modify the clips in bin then use the refresh sequence command to update clips already cut in?
    Media Composer Nitris DX 2018.8 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Wed, Dec 15 2010 5:23 PM In reply to
    • mjc
    • Los Angeles, CA
    • Posts 146
    • Points 1,745
    mjolnarn:
    Yeah, that was my workflow in the past (using Avid P&Z), however this project is a bit different and I was hoping to save time and space importing a bunch of stuff that is just reference anyway.
    We're building a cut of all stills that are just serving as placeholders and some much more detailed animations are being done on each still (in after effect and a 3D box off site).  They'll all come back as "shots" that I'll just replace.
    But showing the client the cuts, I'd like to keep the stills in the right aspect ratio (or, at least, "clean") as we're locking the timing cut, transitions, etc.
  • Wed, Dec 15 2010 5:24 PM In reply to
    • mjc
    • Los Angeles, CA
    • Posts 146
    • Points 1,745
    Kevin Klimek:
    That would be great if it works... I'll get into that today and see if I can make it work.  Thanks for the idea!
    Edit- I couldn't wait, so I tried it.  WOW!  It works.  That is VERY helpful. Thanks Kevin.   How did you find this? (or, where should I have read to know that this could be done?)
    I have two follow up questions now that I can do this...
    1.) Is there a way to set "Pillarbox/Letterbox" as the default for AMA imports? (I'll re-look at settings to see if I can find)
    2.) This seems like we're almost close to resolution independence with that little trick.  Is there any method (in the timeline) to scale up without losing resolution (obviously to the "Center Keep Size" level)?
    Thanks much!
  • Wed, Dec 15 2010 9:55 PM In reply to
    This was a new feature of v5, so that you would have options as to how to handle AMA clips.  (Like the import settings that we currently have.)
    mjc:
    Not to my knowledge.  But it's easy enough to select all of the clips and change the reformat column to the setting you want.
    mjc:
    Also no.  You can only use one of the preset options to determine what is shown.  There is no way to alter those options or do any sort of repositions or anything with the clips.
  • Thu, Dec 16 2010 1:13 AM In reply to
    • mjc
    • Los Angeles, CA
    • Posts 146
    • Points 1,745
    Kevin Klimek:
    mjc:
    Yup, I tried that just to check and found that it worked.  It is also letting me go back and forth without having to re-mount the AMA - which is nice.
    I wonder how hard it would be for avid to add an AMA scaling "effect" (real time or not, it would be helpful).
  • Thu, Dec 16 2010 5:50 PM In reply to
    I won't speculate, but remember this is the first full-blown version of AMA.  I'm sure other features will follow.
