Latest post Tue, Dec 14 2010 3:57 PM by mjolnarn. 3 replies.
  • Tue, Dec 14 2010 1:16 PM
    • nordenthal
    • Joined on Fri, Jul 9 2010
    • Posts 7
    • Points 115
    "Avid DVD by Sonic" - Authoring without transcoding?
    Does exist any new information about a possibility to use "Avid DVD" only for authoring?
    I have MC 5 and produced a HD project (1080i).
    Then I transcoded the product with MainConcept into AVCHD - an exprensive but excellent encoder with results in super quality - and ac3 sound.
    Now I only need an authoring software. "Avid DVD" was included in the MC-package, so I tried to create a blu-ray with this software. But unfortunately the software began to transcode my h264-file...
    Any suggests? Any news in regard to this problem?
    Thanks, Martin
    Filed under: , ,
  • Tue, Dec 14 2010 2:57 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: "Avid DVD by Sonic" - Authoring without transcoding?
    When it comes to bluray creation, Avid Dvd has two options, either to use Mpeg 2 or Vc 1 files.
    For Mpeg 2, Avid Dvd has a built in encoder, for VC 1, the files needs to be preencoded.
    Avchd files are not supported in Avid Dvd, if you need that, you might look at other solutions.
    I would however recommend to take a look at the Vc 1 file alternative in Avid Dvd before starting lookiing for other apps, Sorenson Squeeze is able to create them directly from a QT ref and have ready made presets for that.
    Tomas
  • Tue, Dec 14 2010 3:44 PM In reply to
    • nordenthal
    • Posts 7
    • Points 115
    The problem is not that the AVCHD would not be imported by AVID DVD. They has been imported - I only don't need any "transcoding actions". The software should be able to compile a blu-ray without any transcoding.
    If there is no other way I will change to a MAC and import my .264-file and my .ac3-file into ADOBE ENCORE, this software, as I heard, should be able to do what I wish.
  • Tue, Dec 14 2010 3:57 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    If you absolutely need to create bd discs with avchd files, encore is one of the apps that can do that
    Tomas
