Latest post Thu, Dec 12 2013 12:44 AM by Laurie Hughes. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Dec 13 2010 9:13 AM
    • konx
    • Joined on Mon, Dec 13 2010
    • Zurich
    • Posts 10
    • Points 130
    can't export aaf
    hi there, this is my first post. but it's quite urgent (as usual...).
    i have to export an aaf file for our audio post, but the export always crashes and the avid shows the following message: "Assertion failed: Big_Trouble
    File:/Snapshots/releng.relengintel7_1260842571/vobs/coresw/ame/Projects/Mac/../../src/msmdb/LocalVolume.c, Line 3585"
    what could be the problem here? i tried a lot. also to rebuilt the settingsfile from the project and to rebuilt the media database... nothing works...
    i'm using avid media composer v4.0.5.
    if anyone could help me out there i would really appreciate a lot! thanks!
  • Mon, Dec 13 2010 3:40 PM In reply to
    Re: can't export aaf
    Are you exporting video and audio for the AAF?
    Do you have AMA clips in the timeline?
  • Mon, Dec 13 2010 3:57 PM In reply to
    Also, can you export any portion of the sequence?  Cut it up into smaller segments just to see if there is something corrupted in the media.
  • Mon, Dec 13 2010 4:12 PM In reply to
    • konx
    • Zurich
    • Posts 10
    • Points 130
    hi both of you, thanks so much for your help! to AndrewAction: no, i don't have ama files on the timeline as far as i know... the footage was shot on xdcam, sound in wave (some in aiff). and i just wanna export audio..
    to Kevin Klimek: i tried that too: it also happens with a 1min long sequence...
    thanks again for your help!
  • Mon, Dec 13 2010 4:29 PM In reply to
    Make a copy of your sequence, delete the video tracks, and try again.
    Just to double-check: was your audio imported OMF or MXF?
    Also, can you do a screen grab of your export settings?
  • Mon, Dec 13 2010 10:40 PM In reply to
    • konx
    • Zurich
    • Posts 10
    • Points 130
    thanks again for your kind help!
    after another three hours in front of my avid composer i found the reason (i was so stupid and the solution so simple):
    i tried to consolidate the audio media files into the same folder as the aaf - which seems to be an impossible thing with avid, who needs all mediafiles in the "avid media files" folder direct on a harddisk. so: i just had to consolidate/transcode all audio from the sequence to a harddisk, then export a link only aaf. that simple.
    sorry to bother you! i'm still learning...
    all the best from switzerland
  • Thu, Dec 12 2013 12:44 AM In reply to
    I am having this error with aafs. MC 6.5
    Its only on reimporting the aaf I have made that it becomes apparent.
    FYI
    solution was to commit group clips and then decompose and export the aaf from the decomposed sequence.
