Latest post Thu, Jul 10 2008 4:56 PM by TLS. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Feb 6 2006 4:17 PM
    • john threat
    • Joined on Sat, Oct 29 2005
    • Brooklyn
    • Posts 16
    • Points 250
    moving titles
    how come you cant seem to apply PIP or Blowup onto titles made inside avid?
    Is there a way to move titles around? I have two words that I would like to move from opposite sides of the screen to meet in the middle, but unforunately, when I apply PIP or blowup effect to the title., it moves all the layers underneath as well. Is there a work around for this? It would be nice to pull this off inside of Avid instead of leaving for such a simple effect.
    JT
    http://www.mediathreat.com http://www.johnthreat.com
  • Mon, Feb 6 2006 4:21 PM In reply to
    Re: moving titles
    Open the effect editor while sitting on the title.  you will have "position" sliders that you can change and keyframe to move the title around and "scaling" slider to re-size.
    just make a different title for each word and keyframe.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Mon, Feb 6 2006 9:21 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,495
    • Points 40,410
    Re: moving titles
    "just make a different title for each word and keyframe."
    If it makes your layout easier you can also do it with two copies of the same title on different layers.  When you open the title in the effect editor you can then crop it to show the half you want to move.
  • Wed, Feb 8 2006 7:34 PM In reply to
    • Kevin Sio
    • Syracuse, NY
    • Posts 237
    • Points 2,925
    Re: moving titles
    ...and if you click the little 3D box in the lower right corner of the Effect Controls you get a new range of options.
    K
    HP-xw8600 Media Composer 2.8 [view my complete system specs]
  • Wed, Feb 8 2006 8:34 PM In reply to
    • timw
    • Boston
    • Posts 72
    • Points 1,235
    Re: moving titles
    If you're doing animated titles in Avid, it's worth taking an hour to learn Marquee. There's a free tutorial at Avid.com to get you started, and it's quite adept at the things you're talking about.
    That said, the tips here are great ones. The little 3D box is often the key to many of the things you want to do with titles and other footage in Avid -- a whole new set of options just a button away....
    Best,
    Tim
    Avid
  • Thu, Feb 9 2006 5:10 AM In reply to
    • AK-Jake
    • Leesburg, VA
    • Posts 2,476
    • Points 30,760
    • Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Re: moving titles
    One-step technology, baby!  Boo-yah!
    HP xw8000, dual-3.06 ghz Xeon's; 2 GB of RAM; Nvidia QuadroFX 1100 AGP 8x Graphics Card; 1 - 160 GB 7200x IDE Hard Drive; 1 - 400 GB 7200x IDE Hard... [view my complete system specs]
    I think my memory sucks, but I forget.
  • Thu, Jul 10 2008 10:55 AM In reply to
    • TLS
    • Joined on Wed, Jul 2 2008
    • Cape Town, South Africa
    • Posts 17
    • Points 235
    Re: moving titles
     Hallew
    I know this thread was started two years ago, but I have looked for this marquee tutorial and not found it. Maybe I'm not entering he correct keywords. I don't know ...
    I am trying to move text across screen from left to right and from right to left. I have 11 video tracks, each with a different title and I want them to move across screen in opposite directions at different speeds.
    The problem is that many of them are really long, e.g. "Western Province Football Association". I type it up in the title tool, then in the timeline, I position it on screen and add the movement keyframes. When I play it, however, the title moves across screen from right to left (as I wanted), but all it says is "Western Province Foo" - it's cut off the rest of the title.
    I've been told that this is because I created a master title with all the names on it and then deleted all except one from the master as I went up the video tracks. This means that I can't use the roll tool because I can only use it on the original title when I create it.
    So, I can redo each title and apply the roll tool, but apparently this only rolls titles left to right.
    The same editor who told me about this, said that he'd heard that the marquee tool could help me, but he doesn't know how. I've looked through the manual and not found anything yet.
    Any help? Pleeeeeeeze ...
    Thank you!
    TLS
    even giants started small ...
  • Thu, Jul 10 2008 1:08 PM In reply to
    • clockhart
    • Columbus, OH
    • Posts 252
    • Points 3,060
    Re: moving titles
    Avid Xpress Pro HD 5.7 Dell Precision 390 Core2Duo 2 Gigs Ram Quadro FX 3450 120 Gig Boot 300 Gig Media Drive 200 Gig Media Drive - External [view my complete system specs]
  • Thu, Jul 10 2008 4:56 PM In reply to
    • TLS
    • Posts 17
    • Points 235
    Re: moving titles
    Thanks, will book mark this.
    Am also embarassed to admit that I found out that I need to simply click on "reverse animation".
    Embarrassed
