Latest post Sun, Nov 7 2010 12:09 AM by Jamie-t. 0 replies.
Page 1 of 1 (1 items)
  • Sun, Nov 7 2010 12:09 AM
    • Jamie-t
    • Joined on Wed, Sep 8 2010
    • Posts 3
    • Points 15
    down converters
    howdy,
    I am considering getting the REDBYTE decimator 2 - does anyone have any experience of using this kit with MC?
    My issue is this: I am using a mojo DX on a 24p 1080-1920 36dnxl project and would like to play out to a dvd recorder composite (the export /dvd burn workflow for a 100 min piece takes forever and can sometimes crash) so HD_SDI out from the mojo with embedded audio into the decimator; composite video out, audio RCA out into scart/composite in on dvd recorder....
    Also the 24p picture format output in MC5 is actually 24psf so a cross covert using the video output tool is the only internal option to monitor but then you get judder on monitoring. the decimator 2 should convert this to 24p via the HDMI port but is there a playback sync issue if the audio comes out of the mojo direct to audio monitors?
    jamie
    MC5.03, HP z400, MojoDX, Fostex PD2, Panasonic 47'plasma
    MC5.03, HP z400 Xeon W3540 2.93 8MBMB/1066 QC CPU, 6gb ram, 4tb internal raid, fostex pd2, Panasonic TX-P46S10B 46" Plasma Full HD 1080p [view my complete system specs]
    Filed under: , , , ,
