Latest post Wed, Oct 22 2008 1:19 PM by mjolnarn. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Sat, Mar 18 2006 5:07 PM In reply to
    • DeanHarry
    • Posts 203
    • Points 2,830
    Re: Exception: ADM_DIO_ERROR_OCCURRED, DIOerr:Flamethrower output error - underrun occurred -
    OK, I know but you can click it to dl it in a sec to look at it.  Thanks
    ABS Mayhem G2 (notebook) Pentium M755 2 gigs of ram 128 MB ATI Raedon Mobility 9700 80 gig hd @5400 rpm various extrernal hard drives (Lacie) [view my complete system specs]
  • Fri, Nov 10 2006 6:24 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 105
    • Points 1,150
    I had a similar error 5 minutes into a 24 minute sequence playback.  Shutting down and rebooting allowed me to play the whole sequence, but who needs that hassle?
    Avid Xpress Pro 5.7.5 Mac OS 10.4.10 [view my complete system specs]
  • Wed, Nov 15 2006 9:56 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 105
    • Points 1,150
    jasonsaro:
    uninstall the Flamethrower driver in "Device Manager"  This is the driver that runs the DNA box.  Restart the PC, and a "found new hardware" will pop up.  Let it install the driver again, it will find it, its located in the avid folder.  Thats it, this has happened to me a bunch of times, and all 4 of my MCA's are set to avid spec.  Who knows, just becomes corrupt.
    I don't see the Flamethrower driver in "Device Manager" --- I see Avid Adrenaline though.  Is that the new name for it?
  • Tue, Jun 10 2008 5:17 PM In reply to
    • durstlaw
    • 319 Broadway, NYC 10007
    • Posts 21
    • Points 295
     In Avid Settings, go to Video Display, uncheck "Output to DV Device".  Worked for me.
    ABIT IC7-Max 3 motherboard. (1 AGP slot, 5 PCI) Onboard: 3 USB, 1 IEEE 1394 controller (2) Intel Pentium 4 CPU 3 GHZ NVidea Quadro FX 500/600 PCI... [view my complete system specs]
  • Sun, Oct 19 2008 10:13 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 1,385
    • Points 16,340
    durstlaw:
     I get exact this error when I try to output through my Canopus advc 300 unit, thought that I could have used it for previewing on my big screen wall mount television but unfortunally this doesn´t seems to work, I have tried it on both a V 64 sys and a Xp sys, same error on both sys so I have to either follow the advice to uncheck " output to Dv device " ot just disconnect my unit.
    Capturing with the unit works very well.
    MC 3,05 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 4 * 1024 mb, Sapphire Radeon 2900, Soundblaster... [view my complete system specs]
    Tomas
  • Wed, Oct 22 2008 1:19 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 1,385
    • Points 16,340
     I did some resetting in the preferences for the video output and after that, I am able to use my unit without having these flamethrower output error, works on both V32 and v64
    Tomas
