i will be visiting here often, it seems, as i am switching back to AVID after starting a project in FCP years ago. so here goes it, and your patience with my ignorance is appreciated:
when i try to play my quicktimes (some of them DF, some NDF) in a new avid project (set at 30i NTSC because all my footage is digitized as DVCAM, including the HDV footage, since i started shooting 10 years ago), it plays them out of sync when linked via AMA and also when transcoded, but not when imported. only thing is, when i import, i lose exact TC (start time same, end time different).
mind you all this is without even getting into timelines, converted or newly generated. just raw clips...
what am i doing wrong?
all advise appreciated (have yet to convert via automatic duck, still just testing the media.
MC 5.0.3 / OS 10.6 / macbook pro
Rachel, with QTs created that long ago, the metadata may very well be incompatible with today's AMA code. You may be stuck importing them all rather than using AMA.
