Latest post Tue, Sep 21 2010 7:51 PM by gswilson. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Sep 21 2010 11:34 AM
    • SussexJohn
    • Joined on Wed, Dec 21 2005
    • Brighton, England, UK
    • Posts 556
    • Points 7,710
    Capture Aborted due to lack of progress issue
    I noted this in another thread but that was an MC 3 thread, and the topic got no attention.
    When I first started using MC5, in it's original .0.0 and .0.1 releases I was able to capture HDV footage from my Sony GVHD700 without any problem.  Now I am getting aborted captures 'due to lack of progress'
    I can't recall whether this started on 5.0.2 or 5.0.3
    Is this a known issue?
    MC5.0.3.8, win7 64 pro, Matrox mini 02, Gigabit X58A mb, i7 Q930 2.83GHz, Nvidia Quadro FX 1800, 6Gb 1066 ram, 2 1Tb video HD, 500gb 7200 system HD, 1tb... [view my complete system specs]
    SussexJohn
  • Tue, Sep 21 2010 11:46 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,277
    • Points 52,925
    Re: Capture Aborted due to lack of progress issue
    Can't offer anything other than to check again your raster and project settings. The updates may have altered your presets.
    Using MC 8.10. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Tue, Sep 21 2010 1:53 PM In reply to
    • SussexJohn
    • Posts 556
    • Points 7,710
    Thanks for that idea John.  I have checked my settings and they all seem appropriate.
    I get the same thing at about 8 mins on each tape that I capture.
    SussexJohn
  • Tue, Sep 21 2010 2:14 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,344
    • Points 159,265
    I recently saw this when capturing tapes from a XH A1, turned out to be blank spots on the tape, Liquid was able to capture using EZ Capture but I still had blank spots.
    I did some search for this error message at that time, seems to be " media is no longer coming into your system " and that is what happens at black spots even if there are timecode, could also be something else that causes media to not come in to the system of course
    Tomas
  • Tue, Sep 21 2010 3:50 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,838
    • Points 24,040
    John,
    I use that deck, and periodically get the same error message.  It is due to timecode breaks in the tape in my case.  I just wind back to the spot where the previous clip ended, and continue my capture.  The same message also appears at the end of the captured sequence on the tape.
    Isn't there a check box where you can continue capture in the event of timecode breaks?  BTW, I don't batch capture, I capture the entire tape to disk before editing so that I know I have any resources that I might need available to me.
    Hope this helps,
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Tue, Sep 21 2010 4:04 PM In reply to
    • Zac Hogle
    • Joined on Tue, Mar 30 2010
    • Edmonton, Alberta, Canada
    • Posts 788
    • Points 9,735
    If you go into your capture settings, you can select the 'Capture Across Timecode Breaks' option. This should recue the deck and let it keep capturing if it detects a timecode break.
    Z
  • Tue, Sep 21 2010 4:06 PM In reply to
    • Scott-J
    • Joined on Fri, Jun 11 2010
    • Dallas, Texas
    • Posts 86
    • Points 1,200
    Strange...I got this error all the time using MC3.  Now with MC5, I do not get the error.  For some reason, the upgrade worked for me.  Perhaps you just need to re-install the software.  Is your Quicktime version up to date?
    I also use a Sony HDV deck  HVR-M15AU.
    Timecode - Make sure capture over timecode breaks is checked.  Also, you may want to change the timecode setting...try using internal
    MC 5.0.3 / Intel i7 CPU / 4GB ram / Quadro FX 1700 / Mojo non SDI / Windows 7 Ultimate/ QT 7.6.6 / Windows Media Player 11 [view my complete system specs]
  • Tue, Sep 21 2010 4:09 PM In reply to
    You might also try other pre-roll methods (capture settings) besides "best available".
  • Tue, Sep 21 2010 4:25 PM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 283
    • Points 3,720
    SussexJohn:
    Known Bug. See this post. Geeked
    Gerry
    MC 8.9.2, Win 10 Pro CE, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 980 GPU(Driver 384.94),Samsung 850 Pro 512 GB SSD, 6... [view my complete system specs]
  • Tue, Sep 21 2010 5:22 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,344
    • Points 159,265
    Thanks for telling Gerry, one of the famous 200 - s
    Tomas
  • Tue, Sep 21 2010 7:00 PM In reply to
    • SussexJohn
    • Posts 556
    • Points 7,710
    Thanks for that info Gerry - it is a shame that your post attracted no responses.
    Of course the GV HD 700 deck is from the Sony Z HDV range, and a very widely used range.
    SussexJohn
  • Tue, Sep 21 2010 7:51 PM In reply to
    • gswilson
    • Posts 283
    • Points 3,720
    SussexJohn:
    John,
    I never expected an answer to my post, I was just pointing out that the problem was aslo present with the Sony Z1.
    They are trying to fix over 200 "serious/major" problems with MC5 at the moment - guess we will just have to wait and see how far up the list this one is.
    Gerry
