Latest post Thu, Oct 9 2008 12:08 PM by tikboy. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Feb 3 2006 2:02 AM
    • mir42990
    • Posts 105
    • Points 1,540
    BFX API Error when rendering.
    I just finished making a small Avid FX sequence and now I am trying to render it in xpress. When I try to render it, I get this message. ( I included a dile attachment) I have plenty of space on all of my harddrives! I tried to reboot but it didn't help. Any ideas?
    Dell Workstation: 2.5 GB RAM, ATI Radeon, 550GB hardrives. Avid Xpress Pro HD Studio Essentials: Avid Xpress Pro HD, Avid FX, Avid 3D, Avid DVD, Pro Tools... [view my complete system specs]
  • Fri, Feb 3 2006 5:38 AM In reply to
    • Kolsky
    • Toluca Lake, California
    • Posts 160
    • Points 1,890
    Re: BFX API Error when rendering.
    In Boris Red, under prefs, there is an option to turn off multi-procs...  if it's there in avid fx try that.  This was a tip given to me from the techs at Boris that works everytime.
    PC- dell 650, 2.8 dual xeon, (4) gigs ram, (6) 10k sata drives, 125-145 MB/s [view my complete system specs]
  • Fri, May 9 2008 2:55 AM In reply to
    • tikboy
    • Posts 243
    • Points 2,860
    HI,
    I just want to follow up on this issue.
    I also started getting this error after I reformatted my system.
    (attached image)
    Any other ideas?
    thanks.
    Intel Core2 Quad | 4 G RAM | WinXP Pro, SP2 | Avid XP Studio Essential (5.2.1.2910) - Internal SATA hard drives - G-Raid firewire/usb drive - Mobile hard... [view my complete system specs]
  • Sat, May 10 2008 7:03 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,612
    • Points 78,310
    Long shot but is the drive where it is installed on big enough? It might be the app trying to render to a temp directory as on the system drive and that might not be big enough.. as said.. long shot :)
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Tue, May 13 2008 3:13 AM In reply to
    • tikboy
    • Posts 243
    • Points 2,860
    I have an 80 Gig system drive.
    It is only half full. Is this not sufficient?
    Is there any way to tweak AFX or Avid setting?
  • Tue, May 13 2008 3:46 AM In reply to
    what kind of effect are you using?  what filters inside Avid Fx? what kind of Media inside Avid FX?
    I get this message in boris red when I'm using a still image file in boris that is too large (usually over 3000 pixels by 3000 pixels). For me, I just scale down the still image in photoshop and redo the effect. then it renders fine.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Wed, May 14 2008 2:49 AM In reply to
    • tikboy
    • Posts 243
    • Points 2,860
    thanks.
    I don't have anything beyond 3k pix. in fact everything is generated within AFX. It's a bunch of animated text layers, blur, & lighting.
    I'm trying to optimize my (PC) system by setting it to best performance. I'm also defragging my system & media drives.
    Any other ideas?
  • Wed, May 14 2008 3:40 AM In reply to
    Don't defrag you media drive. They work better fragmented. you can get into lot's of problems defragging the media drives.
    try turning off the blurs and lighting effects and trying the render again. if it works, then turn things on one at a time until you find the problem. you may have just too many effects or lights, or blurs for the effect to handle.
  • Wed, May 14 2008 3:47 AM In reply to
    • tikboy
    • Posts 243
    • Points 2,860
    oh well....will try...
    why can't I have everything! Big Smile
    it's still doin it even after the massage. really strange. I never had this the last time, before I reformatted.
    thanks.
  • Thu, Oct 9 2008 12:08 PM In reply to
    • tikboy
    • Posts 243
    • Points 2,860
    hello,
    well, after a clean reformat and a new, monster quad processors....IM STILL GETTING the BFX API Error! The effect is very simple, just an animated text (zoom).
    I also have 4 Gigs of RAM now and my 80 Gig system drive is only 25% occupied.
    What's wrong? PLease!
