HI,
I just want to follow up on this issue.
I also started getting this error after I reformatted my system.
(attached image)
Any other ideas?
thanks.
Long shot but is the drive where it is installed on big enough? It might be the app trying to render to a temp directory as on the system drive and that might not be big enough.. as said.. long shot :)
Menno
Dutch AV forumFCP2Avid I hear and I forget. I see and I remember. I do and I understand. - Confucius
I have an 80 Gig system drive.
It is only half full. Is this not sufficient?
Is there any way to tweak AFX or Avid setting?
what kind of effect are you using? what filters inside Avid Fx? what kind of Media inside Avid FX?
I get this message in boris red when I'm using a still image file in boris that is too large (usually over 3000 pixels by 3000 pixels). For me, I just scale down the still image in photoshop and redo the effect. then it renders fine.
I don't have anything beyond 3k pix. in fact everything is generated within AFX. It's a bunch of animated text layers, blur, & lighting.
I'm trying to optimize my (PC) system by setting it to best performance. I'm also defragging my system & media drives.
Don't defrag you media drive. They work better fragmented. you can get into lot's of problems defragging the media drives.
try turning off the blurs and lighting effects and trying the render again. if it works, then turn things on one at a time until you find the problem. you may have just too many effects or lights, or blurs for the effect to handle.
oh well....will try...
why can't I have everything!
it's still doin it even after the massage. really strange. I never had this the last time, before I reformatted.
