You can do one of two things.
Delete the effect to see before and then Ctrl-Z to undo and replace it, Ctrl-R, Ctrl-Z....till you'd seen the difference enough times.
You could also use the split screen to see the effect --one side before, one side after.
cheers,
ac
My Two Cents .02Kent Brockman
miky wrote:How do you guys get around THAT limitation?
I work effect until I like it, then move on. If I have a client sitting there, I get input, work it until WE like it, and move on.
I take it your workflow is different?
Jon
Another workaround -- though admittedly a little clunky -- is to add edits to higher video tracks and apply the effects to filler, then monitor various video tracks. Careful not to remove the effect, or you'll have to reapply the add edits.
A better way is to duplicate the same clip on several video tracks, apply different effects to each, then monitor different tracks.
In either case, you can monitor single effects by ctrl-clicking to solo a track, or view combinations of effects by standard monitoring a track -- which displays all lower tracks as well. You can then tailor the combinations by swapping the clips around on the lower tracks.
It works, and when you get the hang of it, it's pretty quick.
miky wrote:thanx guys, @videoppeli: Yeah, my workflow differs a bit from yours, as my clients (either unexperienced or very detail-orientated)), keep changing their mind. They constantly want to see 'what that clip would have looked like', hadn't we added the 2nd effect in a list of 8. So being able to toggle effects on/off would be handy indeed.
So try duplicating your sequences... I know it's not what your asking for, and it would take some creative naming conventions, but I'm not sure there is much of an option at this point...
Two and a half years later, is there still no way better way to selectively disable/enable effects?
