Latest post Sun, Sep 30 2012 11:13 AM by Jeroen van Eekeres. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Feb 2 2006 5:20 AM
    Console Commands
    Wasn't there a handy list of Console Commands that someone posted on this forum?
    I've been searching but not found it ... finally got a printer!
    ~larue  :^>
    Antec P183 Antec CP-850 850W Intel Core i7 Processor i7-920 2.66GHz 8MB Cooler Master Hyper 212 Plus Asus P6T Deluxe v2 OCZ Platinum DDR3-1600 12GB... [view my complete system specs]
  • Thu, Feb 2 2006 7:29 AM In reply to
    Re: Console Commands
    In the Console ... type Help Commands.
    Symphony 8.8.x w/Avid Nitris DX, HP z420, Windows 10, QT v7.7.x, Hexa Core 3.2GHz, 16GB RAM, nVidia Quadro Series 2000 & nVidia v331.65, 2TB Boot,... [view my complete system specs]
    (wwld)
  • Sat, Nov 25 2006 12:16 AM In reply to
    • dbk
    • Joined on Mon, Aug 21 2006
    • Ottawa, Canada
    • Posts 52
    • Points 475
    I tried that, but the list overflowed the console window....and apparently also overflowed the console window's buffer as I couldn't scroll to the top of the "help commands" command's output. Anyone know how to pipe a console command's output -- to a file perhaps?
    I've also seen the console truncate it's own tail, so to speak. See
    http://www.avid.com/exchange/forums/thread/153399.aspx
    dbk
    Dave Kulawick
    Instructional Media
    Carleton University
    MCSoft 2.7on HP xw8200, 3GB RAM, with MojoSDI allso using NewsCutter XP/Adrenaline 6.7 ISIS 1.3 Interplay 1.1 [view my complete system specs]
  • Sat, Nov 25 2006 8:41 AM In reply to
    • mvegas
    • Posts 1,555
    • Points 17,910
    Just curious, have you tried CTRL + A to select all, then CTRL + C to copy, open notepad then CTRL + V to paste the console contents into notepad?
  • Sun, Nov 26 2006 12:51 PM In reply to
    • iedjie
    • Netherlands
    • Posts 236
    • Points 2,740
    Here you go;
    escription>
      admpassthru    -- Enable/Disable OSX software audio passthru.
      admpreload     -- Set the adm preload amount
      admvsync       -- Toggle ADM vsync synchronization
      AllDrives      -- Allows all drives to act as media drives. (Type 'AllDrives -1' for help)
      AllocateMem    -- <no description>
      AllocChecker   -- Toggles the memory allocation tracking gear on/off
      answer         -- Present a popup with 1-3 choices, and return the response
      AROaddClient   -- adds a machine name or IP address to the list of authorized clients for the Avid Remote Objects server
      AROdebug       -- enable or disable debugging statements in the Avid Remote Objects server
      AROlog         -- enable or disable logging traffic for the Avid Remote Objects server
      AROremoveClient -- removes a machine name or IP address from the list of authorized clients for the Avid Remote Objects server
      AROstart       -- starts the Avid Remote Objects server
      AROstatus      -- display status for the Avid Remote Objects server
      AROstop        -- stops the Avid Remote Objects server
      asserT         -- Assert that a given condition is true or generate an exception.
      audiodma       -- Meridian audio DMA buffer control
      AudioHWCalibration -- Displays and allows for setting the software side of Audio Hardware Calibration
      AudioRateMonVerbose -- Set AudioRateMonitor console logging
      AudioThread    -- Use thread for Audio
      AvHLockDebugTogglE -- <no description>
      aviddevicehwunderrun -- Enable/Disable HW Underrun detection.
      aviddeviceinfo -- Get FireBOB Information from the hardware
      AVXRedrawRate  -- Change the millisecond rate that background windows are refreshed
      AVXToggleAltFrameOpt -- Toggles GetAlternateFrame UI Optimization
      BuildTrace     -- <no description>
      ChangeProjType -- Change the project type
      CheckCommands  -- <no description>
      CheckDecks     -- Re-initializes serial communications with decks
      checkmem       -- <no description>
      CheckMob       -- Attempts to diagnose a broken mob.
      CheckSequences -- Check sequences for errors
      CkPE           -- <no description>
      cleanupdatabases -- <no description>
      ClearPE        -- <no description>
      ClearProtocolErrors -- Resets protocol error logs
      CloseAllAVXPlugins -- Close down all AVX plug-ins
      cmd_setImportSlideLength -- Sets the number of frames for subsequent imports of single frame graphics.
      cmdDumpPrecomputes -- Display a list of precomputes for the current project
      CoalesceMem    -- <no description>
      CompactMeM     -- <no description>
      Console        -- Type 'Console help' for complete help.
      consoleloG     -- Turns Console logging on and off.
      consolelogofF  -- Turns Console logging off.
      consoleWindow  -- Get or set the size and position of the console window.
      ConvertColorSpace -- When on, converts 709 HD to 601
      CoreEvent      -- Type 'CoreEvent help' for complete help.
      CoreEventLogger -- Type 'CoreEventLogger help' for complete help.
      CountThings    -- Display count and list of all consumers/converters/producers in current pipes
      DebugMenu      -- <no description>
      DebugWin       -- <no description>
      DesktopSampleOffset -- Set the sample offset to sync desktop audio and video
      DeveloperDongleMode -- Enables or disables DeveloperDongle privileges
      DigitalCutDelay -- <no description>
      DigitalCutFrames -- <no description>
      digitalCutPlayDelay -- Set the timeout value to wait before starting player when doing Digital Cut
      DigitalCutPlayerCycles -- Set minimum player cycles for UI update.
      Disable3D      -- Disables 3DFX on subsequent launches
      DisableFastResize -- Disables the fast resizer on Windows
      DisplayControllerTraffic -- Display controller messages to Composer
      dms            -- DMS Test
      DontWrite      -- Enable/Disable DIDWriter
      DPE            -- <no description>
      DPEX           -- <no description>
      DPEXM          -- <no description>
      dump           -- Dump system state to console
      DumpAVSLBLeaks -- Dumps current AVideoSampleLB leaks
      DumpComponent  -- Dumps a Component to the console.
      DumpDrives     -- Dumps internal drive list.
      DumpHeapInfo   -- <no description>
      dumpinputmixer -- Dump state of input mixer
      DumpLocalVolumes -- Dumps LocalVolume list.
      DumpMachineAttributes -- Displays template attributes for each machine
      DumpMachineTemplates -- Displays deck templates read into system
      DumpMaxPeaks   -- Display Audio Meter Max Peaks
      dumpmetertimestats -- Dump stats on the meters
      DumpMob        -- Dumps a Mob to the console.
      DumpPaneRegistry -- dumps the contents of the QA Partner pane registry
      DumpPlayHistory -- <no description>
      dumppmr        --
      DumpProfileByTotal -- <no description>
      DumpProtocolErrors -- Displays serial communications errors
      DumpRecordMon  -- Dumps to the console the composition in the Record Monitor.
      DumpSlots      -- Dumps to the console the pending memory alloc/lock (slots) list
      DumpSourceMon  -- Dumps to the console the composition in the Source Monitor.
      DumpVolumeGroups -- Dumps list of VolumeGroups.
      DumpVolumes    -- Dumps internal volume list.
      echo           -- Enables or disables echoing script commands to the console.
      Enable3D       -- Enables 3DFX on subsequent launches
      EnableBinDialogue -- Toggles displaying Bin dialogue to user during Bin operations
      EnableFastResize -- Enables the fast resizer on Windows
      enableHD       -- Reset the firehose board and get out of the decoder hung state.
      EnablePCEdit   -- <no description>
      EnableSWCC     -- Enables software color correction
      exiT           -- Exit a script.
      Expect         -- Assert that every line in a block will generate a given exception.
      exportOMFI     -- Export an OMFI composition.
      FakeDeck       -- Uses a 'virtual' deck for deck control
      fatal          -- Abort a script with an assertion 'fatal' error message.
      fillmem        -- <no description>
      FixOMFIMobInSrcMon -- <no description>
      ForceVideoUnderrun -- Forces video underruns. (Type: 'ForceVideoUnderrun -1' for full help.)
      foreach        -- Foreach statement using a comma separated list.
      forEachBinMob  -- Executes a command for each Mob.
      forEachMob     -- Executes a command for each Mob.
      GammaConform   -- GammaConform toggle 8 bit color correction gamma control range between 16-235/0-255
      Global         -- Create a global variable.
      GraphPlayerPipes -- Display a graph of the player pipes from the current player
      help           -- Help the user.
      iF             -- iF statement (scripts only).
    Single-statement if structure:
    iF cond THEN stmt [ELSE stmt]
    iF condition THEN statement
    [ELSE statement]
    iF condition
      THEN statement
      [ELSE statement]
    Multiple-statement if structure:
    iF condition
      THEN Statement-List
      END iF
    iF condition THEN
      Statement-List
      ELSE statement
    iF condition
      THEN Statement-List
      ELSE Statement-List
      END iF
    If statements are valid in scripts only.
      iNewsDebug     -- Temporary debugging for iNews Capture Mgr Control
      LockMixdownMem -- Toggle locking down of memory for mixdowns
      Log            -- Open a log file or close the current log file.
      LogAVSLBLeaks  -- Enables/Disables logging of AVideoSampleLB leaks
      LogCalls       -- Direct all calls to Avidtalk commands into the logfile.
      LogClaims      -- <no description>
      LogLocateBuffers -- Enables/disables locate buffer log
      LogTest        -- Test the log file triggers
      MarkToLoopDelay -- <no description>
      MarqueeDebug   -- Enable/Disable Marquee debug messages
      MaxBrushStroke -- <no description>
      mem_more_masters -- <no description>
      MemClearTotals -- <no description>
      MemPrintStats  -- <no description>
      MeridienColorFX -- Rotates hue on all color effects in sequence
      MeridienDSK    -- <no description>
      mixtool        -- Open deprocated mix tool
      MobDumpOptions -- Sets display options for dumping Mobs to the Console.
      MobSummary     -- Displays a one-line summary of a Mob.
      MonitorProtocol -- Select protocol to monitor
      MotionFXSize   -- MotionFXSize on/off
      msm            -- Type 'msm help' for complete help.
      MsmIsOnlineFileCheck -- true means IsOnline uses filesystem (slower, accurate) vs cache (faster, less accurate).
      MultithreadFX  -- Enable/Disable multithreaded rendering of FX
      on             -- Define an event handler.
      openBin        -- Open a Bin.
      OpenProject    -- <no description>
      OsPrintf       -- Enables/Disables OsPrintf. Type 'OsPrintf help' for complete help.
      PaneIDkey      -- sets up F12 to be the Pane Dump key
      PauseToStopDelay -- <no description>
      PlayEvent      -- Type 'PlayEvent help' for complete help.
      PlayLength     -- <no description>
      playStats      -- play stats command
      Plog           -- <no description>
      powerman       -- Enable/Disable handling Power Management broadcast messages from OS
      preloadSafe    -- set preload mechanism to old way
      PrintACFDefinition -- List the registered ACF Component definitions.
      PrintPlayerPipes -- Display the player pipes from the current player
      PrintPlayHist  -- <no description>
      PurgeAllUnreferenced -- <no description>
      put            -- Store expression into a variable.
      QAPdebug       -- turns on and off debugging statements in QA Partner extension functions
      QAPexceptions  -- <no description>
      QAPidleProc    -- <no description>
      QAPinit        -- register QA Partner extension functions
      QAPtoolManCounters -- <no description>
      QuitMC         -- Exits from the MediaComposer application
      ReaderCache    -- Enables/disables reader caching for sample mode play
      RecreateTitleMedia -- <no description>
      Redir          -- <no description>
      RenameMediaFiles -- <no description>
      reneW          -- Resets the problem and error counters.
      RepairKNMasks  -- <no description>
      RepairKNStart  -- <no description>
      RepairMob      -- Attempts to repair a broken mob.
      RepairSequences -- Check sequences for errors and attempt to repair errors
      repeat         -- General looping keyword.
      ResampleCapturedAudio -- Turn on/off DV audio resampling during capture
      RestoreMaxALBMSize -- Restores the maximum size of the Locate Buffer Manager to its default - Requires relaunch
      RestoreMaxStreams -- <no description>
      Run            -- Load a script file & execute any non-definition commands.
    The script file name is taken literally and must not be enclosed in quotes.
      RunScript      -- Load a script file & execute any non-definition commands.
    The script file name may be any string expression.
      SB             -- <no description>
      ScratchMode    -- ScratchMode [0 = dup, 1 = both]
      SetAudioLoopPlayPerformance -- <no description>
      SetAudioTestingState -- <no description>
      SetAVX2DebugLevel -- Set the verbosity of console reporting.
      SetConstantBinTitles -- Toggles modification to the bin name in the window title
      SetDoNotRetFromPlay -- If (1) then play will NEVER allow the UI to update.
      SetEcho        -- Flag to echo all executed commands to the console.
      SetMaxALBMSize -- Sets the maximum size of the Locate Buffer Manager - Requires relaunch
      SetMaxStreams  -- <no description>
      SetMixdownConserve -- Set mixdown memory conserve factor
      SetMonitorExceptionVerbosity -- Sets the user feedback level used by the AMonitorPane when it encounters player exceptions
      SetMouse       -- Set mouse play parameters
      setnamefile    -- sets preempting input for AFileDialog::NameFile.
        path - path to be used during preemption
        null args echos the current values
      SetPE          -- <no description>
      SetPEmask      -- <no description>
      SetPEsize      -- <no description>
      SetPlayerUIbalance -- This command alters the delicate balance that adjusts the UI update frequency vs Player underruns/dmfas
      SetPrecompAutoDelete -- Enable/Disable automatic deletion of unsaved precomputes
      SetRenderThreadWait -- Change the amount of time the scheduler waits to let the render thread run
      SetRescanWarnings -- <no description>
      SetResizeType  -- SetResizeType [1 = nearest neighbor, 8 = anti-aliased bilinear, 9 = polyphase]
      setrunoncebuffer -- Enable/Disable direct sound run once capture buffer.
      SetShowBuildPipes -- Display the player pipes whenever the pipes are rebuilt
      SetSleepTime   -- Set time to sleep between null events
      SetUndoMan     -- <no description>
      SetUpdateWhilePlayingOn -- Set whether globalState should be updated during play.
      SetVideoVitalsFromTrackGroup -- Enable/Disable SetVideoVitalsFromTrackGroup
      SetVolumeLatency -- Slows down the volume's I/O to simulate the slow volumes. Latency is in msec
      showbptime     -- Toggles display of build pipes times in the console
      ShowCmd        -- Hidden command to enable using hidden commands.
      ShowMixdownMemStats -- Toggle showing mixdown memory statistics
      ShowVolumeInfo -- Shows the information about all volumes
      Standby        -- <no description>
      StatTest       -- <no description>
      StepToTrim     -- <no description>
      Subsys         -- Control the debug parameters
      SuppressUnderruns -- Turn suppression of underruns on/off. (Type: 'SuppressUnderruns help' for help using this command.
      testerr        -- <no description>
      testNew        -- <no description>
      ThreadedPlay   -- Sets the use of player thread
      tmDump         -- <no description>
      tmDumpAllMethodLists -- <no description>
      tmDumpAllTools -- <no description>
      ToggleACFClientMonitorForAVX -- Toggles use of ACF Client Monitor for avxInstance_v1::DrawToVideoBuffer.
      ToggleAVXRedraw -- Toggle background redrawing when plug-in UI is up
      ToggleAVXResizing -- Enable/Disable AVX effect resizing
      togglerunmetersinplaycmd -- Toggle doing the meters directly in PlayCmd
      toggleStatSpace -- Toggle statistics space calculation
      ToggleWFfailLoudly -- Toggle advanced waveforme engine propagating exceptions
      ToggleYUV      -- Toggles use of board for 1:1 <-> YUV
      TopOffStream   -- Turn topping off of stream on/off. (Type: 'TopOffStream help' for help using this command.
      tracefd        -- Enables and disables file dialog tracing.
      TrimToUpdateDelay -- <no description>
      UseEvertz      -- <no description>
      UseSWRTFXScheduler -- Use the scheduler designed specifically for SWRTFX player pipes
      ValidateConfig -- Validates the current deck configuration against the decks actually connected.
      verbosE        -- Sets the level of information that goes to the screen. Verbose level must be between 0 and 5. 0 means don't echo anything, 5 means echo it all. Standard level is 4.
      VideoThread    -- Use thread for Video
      VTRE           -- Accesses VTR Emulation debug information.  Type 'vtre help' for more info.
      VTRE           -- Accesses VTR Emulation debug information.  Type 'vtre help' for more info.  VTRE           -- Accesses VTR Emulation debug information.  Type 'vtre help' for more
    mobo MSI P55-GD65, CPU Intel i5-750 @ 3.2 Ghz, memory G.SKILL F3-10666CL7D 2x4GB, Videocard Nvidia Quadro FX 3700, PSU OCZ 500MXSP, Harddisks; Crucial... [view my complete system specs]
  • Sun, Nov 26 2006 5:01 PM In reply to
    • Brian Suttie
    • Edinburgh, Scotland
    • Posts 917
    • Points 11,570
    If you want a list that includes Ws and Xs go here
    regards
    Brian
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Sun, Nov 26 2006 11:13 PM In reply to
    • dbk
    • Ottawa, Canada
    • Posts 52
    • Points 475
    I had tried that too, actually. I guess the fact that the console's buffer overflows means that not only can the humans not see what's at the top of "help commands" output but neither can Windows.
    Thanks for the listing, Brian!
    dbk
    Dave Kulawick
    Instructional Media
    Carleton University
    “The only truly obvious things are those things that you already know. (And, regrettably, not everyone is you yet.)” www.43folders.com
  • Fri, Jan 27 2012 5:35 PM In reply to
    • joshdvx
    • New York, NY
    • Posts 551
    • Points 6,640
    Sorry to dig up an old thread but, is there a place where I can get the latest Console Commands for MC 5.5 and MC 6?
    Interested in learning Media Composer? In NYC? I teach Media Composer classes tailored for reality tv assistant editors. http://joshluddeni.com [view my complete system specs]
  • Wed, Mar 21 2012 11:55 AM In reply to
    Go to Console fast menu and select "Open log file". Select where you want your logfile stored. In the commandline type "help commands" and when the scrolling is over go to fast menu and select "Close log file" and bingo you have a copy of all console commands (nearly). There is a good document by Paul Samsons describing some of the most used commands . It can be found here.
    Bet regards
    Beent
    HP Elitebook 8540W, win7 8GB Ram [view my complete system specs]
  • Wed, Mar 21 2012 12:35 PM In reply to
    wow ! supertip
    thanks!
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Sun, Sep 30 2012 9:44 AM In reply to
    • Arouri
    • Joined on Sat, May 20 2006
    • Jordan Nationality
    • Posts 38
    • Points 420
    Great i like them ... thanks
    Mac Pro 12-core - 16 GB Ram - 12TB HDD - Avid Symphony 6.5 with Nitris DX and Euphonix MC Color for Artist color. [view my complete system specs]
    • ALL THE BEST ALL THE TIME
    • Do not Say " I Can not " but Say " I Will Can "
  • Sun, Sep 30 2012 11:13 AM In reply to
    Thx for that... Yes
    Jeroen van Eekeres
    www.mediaoffline.com
