Latest post Thu, Feb 9 2012 3:11 PM by Joachim Claus. 157 replies.
Page 4 of 11 (158 items) « First ... < Previous 2 3 4 5 6 Next > ... Last »
  • Fri, Jul 30 2010 2:11 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 8,880
    • Points 104,555
    Re: Are you having trouble with AvidDVD re-encoding DVD compliant MPG2 files?
    I have switched boot now and created a file from SS5 , source media DNxHD 185x, using preset DVD_PAL 16x9_Lg and changed that one in this way:
    VBR speed rates Max 8000   Avg 6800    Min 4000
    Stream Type  Program
    Filter setting:
    Deinterlace Adaptive Blend/Discard   - Discard Top Field
    No ther changes, will switch boot now and do a test on Avid Dvd 6,1,1
    Mac: 17" Macbook Pro i7 2,66 ghz with 8Gb Ram, 500gb 7200rpm drive___ PC: W 7 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem 8 GB Corsair... [view my complete system specs]
    Tomas
    a very happy TAW 5 user
  • Fri, Jul 30 2010 2:23 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 8,880
    • Points 104,555
    mjolnarn:
    Stream Type  Program
    Filter setting:
    Just tried, the file from SS5 is beeing reencoded by Avid Dvd 6,1,1, will check my settings in SS6 and do a new test
    Tomas
  • Fri, Jul 30 2010 3:09 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 8,880
    • Points 104,555
    I have just successfully used a file encoded with SS5 with the above changes to the preset and one more change made, change the aspect from unconstrained to letterbox.
    Anyone else ??
    Tomas
  • Fri, Jul 30 2010 3:34 PM In reply to
    • MichaelPaine
    • Joined on Fri, Oct 5 2007
    • Alta, Finnmark, Norway
    • Posts 77
    • Points 1,005
    I tried the same preset with the same changes, but no luck. Avid DVD 6.1.1 still wants to transcode.
    #1: Four HP xw4300, 3GB RAM - 3,6 GHz Dual-Core, Windows XP Pro, Media Composer 3.1.3.13 w/Mojo DNA, QuickTime 7.5.5, NVIDIA Quadro FX1400 - 128MB - driver... [view my complete system specs]
  • Fri, Jul 30 2010 3:39 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 8,880
    • Points 104,555
    Maybe this is only possible with the last version of Squeeze, version 6
    edited.  did you set your encoding speed in Avid Dvd to a bit above 8 mbps, I used 9000 myself ?
    Tomas
  • Fri, Jul 30 2010 4:13 PM In reply to
    • MichaelPaine
    • Posts 77
    • Points 1,005
    I've tried umpteen settings, but nothing helps as long as my SS5 encoded file is VBR.
  • Fri, Jul 30 2010 4:18 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 8,880
    • Points 104,555
    Ok, I am doing a one hour project encoding now with SS6, will publish the SS5 preset after that to see if anyone else are lucky, otherwise, it seems to be the latest bundle that are needed for this to work well
    Tomas
  • Fri, Jul 30 2010 7:53 PM In reply to
    • MichaelPaine
    • Posts 77
    • Points 1,005
    The strange thing is, I know I haven't always had this problem. Maybe it's something that came along when I updated to SS 5.1?
    I'll try reinstalling 5.0 and checking when I get my hands on the 5.0 installer tomorrow.
  • Fri, Jul 30 2010 10:18 PM In reply to
    This just in!  I think I have discovered the source of this problem.   Assuming your other settings are correct, this is what I've found will ALWAYS prevent Avid DVD from accepting compliant files.  Your audio file mus be just clightly longer than your video stream.  Even if they say they are the same, i will not work.  Do a second separate audio encode and make the time slightly longer.  It's worked everytime now, and before, it never worked.  See here for my full story:
    http://community.avid.com/forums/t/87084.aspx
  • Sat, Jul 31 2010 12:47 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 2,796
    • Points 35,295
    Have you considered that this may be a quirk with Sorensen rather than DVDit?
    Twin Dell U2410, PhenomII 965, AMD770 mobo, 8gigXMS DDR, Quadro-Free ATIx4850, Audigy2zs, 1TB SATA system drive, 2TB SATA render, 1TB SATA media storage... [view my complete system specs]
    Using MC 6.0, Vegas Pro 11, Liquid 7.2, Boris FX, DVDit6proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sat, Jul 31 2010 1:51 AM In reply to
    TVJohn:
    Actually, as I have revised my other post, I just determined that even though Avid DVD is not saying "transcoding", but rather, "building movies" - it is, in fact transcoding.  I found the resulting bluray and SD dvd  files had both actually been transcoded (re-encoded).  Their bit rates had become what was in my project settings menu, and in the case of the bluray file, it had become an mpeg 2.
    It is very, very unlikely that every single kind of Sorenson output, and every variation, would always be rejected by Avid DVD because of a problem with Sorenson Squeeze.  This had been a long-standing issue with Avid DVD, and the only thing that has been done with this software to update it has been changing the color and artwork of the loading screen and desktop icon.
    If you want to make DVDs of weddings and your kids T-Ball game, Avid DVD is The Bomb.  If you want a real Authoring tool that's not an Avid/Sonic shell game, I suggest Encore, or ditching Avid and going to FCP, which bundles with an excellent authoring tool.
  • Sat, Jul 31 2010 8:09 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 8,880
    • Points 104,555
    I did a night render redoing my latest project, 1 hour 2 minutes of project took 7 hours 30 minutes to create with SS6...   wow ....
    The file however looks great and it runs straight through Avid Dvd without beeing transcoded, so far so good and the disc burnt without a menu looks real great when looking at it.
    When I start doing menu editing in Avid Dvd using this file the fun stops, everything runs very very slowly and I get no picture - video into my animated buttons starting from button 3, it is all just grey.
    I have spent to many hours with this test now and my feelings right now is to drop it, if you have a Mac, know someone who has or have intentions to buy one, maybe just a lap, I would strongly recommend Bitvice for your preencodings, works excellent together with Avid Dvd 6,1,1
    Tomas
  • Sat, Jul 31 2010 8:20 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,264
    • Points 66,730
    • Moderator: MCA PC
    TVJohn:
    I'll go along with that John.
    I have never used Squeeze to encode with.... and I never had any of the troubles mentioned here and in numerous other posts. I cannot say I have never had any problems with Avid DVD..... but those were other problems.
    Not that I have anything against Tomas solving the Squeeze problem. That would be nice if he does.
    Already people are reporting that AvidDVD 6.1.1 is working for them
    Regards,
    Douglas
    System 1:AMC MojoDX 6.0.1.1 - Windows 7 64 bit Pro SP1 - Nvidia Quadro FX3700, 275.89driver - Quicktime 7.7.1 - 24GB memory, i7 980 3.33GHz CPU - Asus... [view my complete system specs]
    Douglas, Japan - Video Tutorials that mere mortals can understand  http://www.gaijin-eyes.com
  • Sat, Jul 31 2010 8:40 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,264
    • Points 66,730
    • Moderator: MCA PC
    Motion Path:
    Of course.
    The files must be either DVD or Blu-Ray compliant to fulfill the specifications set down by the bodies that make the standards for them.
    E.g. AvidDVD has the following norms.
    If you feed it anything other than those listed below...... they will be transcoded.
    DVD-compliant video
    Avid DVD by Sonic supports video with the following DVD-compliant settings:
     Video format   Frame size   Frame rate (fps)   Aspect ratio  Bit rate (Mbps)   GOP size
    MPEG-1    NTSC (525/60)   352 x 240  29.97   4:3   1.856 max.   18 frames max.
      PAL (625/50)   352 x 288  25   4:3   1.856 max.   15 frames max.
    MPEG-2
    (MP @ML)   NTSC(525/60)   720 x 480  29.97   4:3,16:9   9.80 max.   36 fields/
             18 frames max.
      PAL(625/50)   720 x 576  25   4:3,16:9   9.80 max.   30 fields/
             15 frames max.
    Blu-ray-compliant video
    Avid DVD by Sonic supports MPEG-2 video with the following Blu-ray-compliant settings:
    Codecs    MPEG-2: MP @HL and MP @ML
      MPEG-4 AVC (elementary streams only): HP @4.1/4.0 and MP @4.1/4.0/3.2/3.1/3.0
      SMPTE VC-1 (elementary streams only): AP @L3 and AP @L2
    Max Bit Rate   40 Mbps
    HD    1920 x 1080 x 59.94i, 50i
      1920 x 1080 x 24p, 23.976p
      1440 x 1080 x 59.94i, 50i
      1440 x 1080 x 24p, 23.976p - AVC and VC-1 only
      1280 x 720 x 59.94p, 50p, 24p, 23.976p
    SD    720 x 480 x 59.94i
      720 x 576 x 50i
    DVD-compliant audio
    Avid DVD by Sonic supports audio with the following DVD-compliant settings:
    Audio format   Sample rate (kHz)   Sample size (bits)   Audio Channels   Bit rate (Mbps)
    PCM
    (AIFF, WAVE)   48    16    Mono  Mono: 0.8
          Stereo    Stereo: 1.6
    Dolby Digital (AC-3) 48    16    2/0 (stereo) 0.064-0.448
          2/1 (2 front, 1 rear)
          2/2 (2 front, 2 rear)
          3/0 (3 front)
          3/1 (3 front, 1 rear)
          3/2 (3 front, 2 rear)
          5.1 (3 front, 2 rear, 1 LFE)
    Blu-ray-compliant audio
    Avid DVD by Sonic supports audio with the following Blu-ray-compliant settings:
    PCM
    (AIFF, WAVE)   96    16    Up to 8 Channels   Mono: 0.8
            Stereo: 1.6
          3/0 (3 front)
          5.1 (3 front, 2 rear, 1 LFE)  0.064-0.448
    Sorry the tables did not paste very well into this post.
    Look it up in the help menu in AvidDVD!
    Regards,
    Douglas
  • Sat, Jul 31 2010 8:44 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 5,264
    • Points 66,730
    • Moderator: MCA PC
    Tomas,
    Thank you for trying to get to grips with the Squeeze problem.
    However I have one question that I can never seem to answer.
    mjolnarn:
    What is the point of taking all this time to try and get a file that will run straight through AvidDVD............... when AvidDVD will do this by itself in the exact format that it needs to make the DVD or Blu-Ray?
    It will also take time..... but it will also be doing all the menus etc. at the same time.
    I still cannot see why everyone is banging their heads on the wall and trying to get Squeeze to work.
    Then again, I may well be blind.
    regards,
    Douglas
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
