Latest post Sat, May 5 2018 8:37 PM by George Angeludis. 784 replies.
Page 51 of 53 (785 items) « First ... < Previous 49 50 51 52 53 Next >
  • Sat, Sep 30 2017 5:23 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 578
    • Points 6,520
    Re: MC5 Diary
    yeah, that's one big surprise:
    i was able to record c4k 4:2:2_10bit  23.98  all i @400mbps on my lexar  1000x 64GB (150r 80w)
    seems to work without problem...
    mc 2018.8 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (398.36) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Sat, Sep 30 2017 6:07 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,399
    • Points 15,405
    Re: MC5 Diary
    touviere7:
    Good morning,
    at least here morning coffee and Avidnews. How long did you record?
    My 128GB ScanDisk Extreme for 95mb / s SDXC1, recorded about 20s: 4k 25p ALL-I 400mbps. Then the recording stops, but the recording is saved.
    FHD 200mbps is all right.
    V.
    AVID MC2018.8 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Sat, Sep 30 2017 7:05 AM In reply to
    • touviere7
    • los angeles
    • Posts 578
    • Points 6,520
    Re: MC5 Diary
    20'22" and it stopped, because that's it on a 64gb card. then i tried again with a lot of movement and it filled the card once again. pretty happy about that. i just ordered a couple of 128gb.
  • Sat, Sep 30 2017 4:50 PM In reply to
    Re: MC5 Diary
    It seems that Lexar 1000x which is a relatively cheap card works with 400M Intra.
    I use Kingstons 64gb which are even cheaper and fine for everything except this one which they write for 18-20 secs.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.7 with Symphony Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sat, Oct 28 2017 8:36 PM In reply to
    Re: MC5 Diary
    Off Topic cont. Smile
    GH5 Firmware 2.1.
    Desktop
  • Sat, Oct 28 2017 9:00 PM In reply to
    Re: MC5 Diary
    The only files from GH5 that are not supported in MC are from the new MP4 HEVC recording format.
    Desktop
  • Sun, Oct 29 2017 7:51 AM In reply to
    • Vilem
    • Prague
    • Posts 1,399
    • Points 15,405
    Re: MC5 Diary
    George Angeludis:
    GH5 Firmware 2.1.
    Hello George,
    I noticed with the new GH5 firmware (2.0 and 2.1) that even when I have autofocus turned on, switching to some recording types (all 8 bits - except UHD 50p) will deactivate autofocus. It's the same on your GH5?
    I raised the question on the Panasonic, but so far no response.
    Regards
    Vilém
  • Tue, Oct 31 2017 1:04 PM In reply to
    Re: MC5 Diary
    I never use autofocus.
    But I will check it for you.
    You mean continous focus?
    Desktop
  • Tue, Oct 31 2017 2:08 PM In reply to
    • Vilem
    • Prague
    • Posts 1,399
    • Points 15,405
    Re: MC5 Diary
    Thank you.
    It does not matter if AFS / AFF or AFC. Disables AF menu.
    It's a thing I noticed during the tests, but it's not written anywhere.
    Mostly I do not have AF, but I need to know exactly how GH5 behaves.
    V.
  • Tue, Oct 31 2017 8:05 PM In reply to
    • Vilem
    • Prague
    • Posts 1,399
    • Points 15,405
    Re: MC5 Diary
    Hi George,
    You do not have to search AFF anymore. My problem with setting GH5. On 8-bit codecs, a VFR setting was set in which AF is disabled. I have not noticed that the VFR option remains on even after transferring the recording format.
    V.
    P.S.: Link to forum where it is discussed.
  • Wed, Nov 1 2017 3:20 PM In reply to
    Re: MC5 Diary
    Again I mainly use 10bit codecs (what do I need an 8bit except in the case of 4K 50p/?).
    VFR remains on if the codec match the VFR settings. Meaning that the setting allows for VFR.
    I have set what I need at C1(photo) C2(Timelapse) and C3 1,2,3(VFR 180,150,100).
    And at the Creative Video (M) I have the main shooting settings which are FHD 50p 200 (All-I) 10bit.
    Desktop
  • Tue, Nov 14 2017 12:05 AM In reply to
    Re: MC5 Diary
    A possible bug:
    "Fit To Fill doesn't send the newly created clip at the selected bin during the timewarp export"
    8.9.3.
    Desktop
  • Fri, Nov 17 2017 5:59 AM In reply to
    Re: MC5 Diary
    Smile
    Desktop
  • Mon, Dec 11 2017 8:55 PM In reply to
    The most power green screen is inside MC and it is of course Spectramatte.
    Even the toughest keys can be pulled.
    However the scalling option at 8.9.4. is not working right.
    Ticking the fixed aspect doesn't work as it should.
    Desktop
  • Fri, Feb 16 2018 3:36 PM In reply to
    Re: MC5 Diary
    It's not well documented or a humble move from Avid's part.
    With Media Composer subscription you get (untill MC has it's own 4K titler) NewBlueFX Titler 5.0!
    This is huge even if someone doesn't like too much NewBlue FX Titler.
    Excellent move Avid.
    Desktop
