Latest post Tue, Jun 8 2010 1:33 AM by Larry Rubin. 15 replies.
  • Sat, Jun 5 2010 8:10 PM
    • micha2489
    • Joined on Mon, Jun 16 2008
    • Posts 14
    • Points 210
    Getting ready for MC 5 - Uninstalling/deinstalling old version
    Hello everyone! Huh?
    Does any of you know the best way to prepare one's system for upgrading especially to MC 5 (running MC 4). I do not want to reinstall Windows XP prior to an upgrade. However I have in mind that deinstalling before installing a new MC version might require manual changes to the registry. Does this still hold true?
    I could not find any information on Uninstalling/deinstalling in the Avid Media Composer/Basic Guide, nor Avid Installation Guide nor could I find much information in the forums (eg "Posting Suggestions & General Information").
    Please help or tell me if I have overseen important information.
    Thank you very much in advance!
    Micha
  • Sat, Jun 5 2010 8:22 PM In reply to
    Re: Getting ready for MC 5 - Uninstalling/deinstalling old version
    The ReadME for v5 (when released) should have instructions on Installation procedure.
  • Sat, Jun 5 2010 8:37 PM In reply to
    Kenton.VanNatten:
    Until then the readme that came with MC 4 should give you a fairly good idea of what night be needed
  • Sat, Jun 5 2010 9:01 PM In reply to
    Here is the Avid officially recommended uninstall/reinstall procedure.
  • Sat, Jun 5 2010 10:09 PM In reply to
    • yon1
    • Joined on Sat, Apr 15 2006
    • Posts 317
    • Points 4,540
    Hi
    I have the trial version of MC installed and have not yet installed the version I've Bought
    Should I wait to install MC 5 ? Does it need to be installed ont top of 4 ?
    MC 5.04 windows 7, Core i7 CPU, MoBo Asus P6X58D , 6GB RAM, Quadro 2000D, 512GB & Raid 0 1TB, [view my complete system specs]
    Yonatan
  • Sat, Jun 5 2010 10:14 PM In reply to
    Each version of Avid is an entity unto itself. It is never installed on top of an existing version. The existing version must be uninstalled first. If you can wait a few more days, I would, if I were you.
  • Sat, Jun 5 2010 10:19 PM In reply to
    • micha2489
    • Posts 14
    • Points 210
    Larry Rubin:
    That was the information I was looking for but somehow was unable to find.
    Thank you all!!
    Micha
  • Sat, Jun 5 2010 10:25 PM In reply to
    You're quite welcome, Micha. We're always glad to help out.Yes
  • Mon, Jun 7 2010 5:18 PM In reply to
    • Jill
    • Joined on Tue, May 4 2010
    • Posts 13
    • Points 175
    I have a dual-boot/dual drive computer with a separate Windows 7 Professional boot running off each drive. I am currently running MC 4.05 under one of the Windows 7 boots. I know MC 4 is not supported on Windows 7, but I bought and installed MC 4 last month so I could upgrade to MC 5 for free, and MC 4 has worked well for me under Windows 7.
    I'd like to be able to test MC 5 in trial mode on one boot, with my working/activated MC 4 on the other boot. Is this possible?
    When I decide to activate MC 5, I assume that all I need to do is deactivate MC4 on the other system boot. Is this assumption correct?
    Jill
    Media Composer 7, Dell Studio XPS 435MT (i7-920), Windows 7 Professional 64bit, 15GB Ram, Nvidia Quadro FX 3800, QT 7.6.8, Canon HV30, Sony NEX-6. [view my complete system specs]
  • Mon, Jun 7 2010 5:27 PM In reply to
    Jill:
    Yes, that is correct. You must deactivate MC 4 first.
  • Mon, Jun 7 2010 11:59 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 771
    • Points 9,415
    Larry Rubin:
    I downloaded v3.5.9...Is it necessary to perform all the steps in that link when going from v3.1.1 to v3.5.9?
    Or can I just follow these directions as stated in the 3.5.9 Readme...
    If you are updating from a previous release, you should uninstall the existing editing application. You should also uninstall Digi Drivers using Add/Remove from the Control Panel. Reboot the system and then install the new editing application.
    Thx, JR
    Media Composer v3.5.9.15-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Windows XP Pro SP3-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial... [view my complete system specs]
    That's right...an xw8000.
  • Tue, Jun 8 2010 12:26 AM In reply to
    JR:
    That procedure is meant for full clean installs of a new version replacing an old one (MC 3 to 4, for example). In your case you can defer to the readme instructions.
  • Tue, Jun 8 2010 12:45 AM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 771
    • Points 9,415
    Larry Rubin:
    JR:
    Thanks Larry...
    I don't recall seeing that link and info when I went from Xpress Pro to MC so I probably never ran through it.  Would there be any harm in following that procedure now, before going to v3.5.9?
    Also, is there a "Avid folder hierarchy" list somewhere that would show where the various Avid folders (Attic, AVX2, etc) should be located?  I seem to have a few duplicate folders on my system that might not need to be there.  Thx.
  • Tue, Jun 8 2010 1:07 AM In reply to
    JohnnyReboot:
    No, it can't do any harm, but I'd go ahead and follow the readme instructions first, and if everything works normally as expected, you've saved yourself significant work and time.
    JohnnyReboot:
    ...is there a "Avid folder hierarchy" list somewhere that would show where the various Avid folders (Attic, AVX2, etc) should be located?
     Not that I've seen. But I believe the path is C:\program files\Avid\Avid Media Composer\Avid Attic. I'll double check on the AVX folder tomorrow, but most everything Avid specific is in the main Avid Media Composer folder.
  • Tue, Jun 8 2010 1:27 AM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 771
    • Points 9,415
    Larry Rubin:
    JohnnyReboot:
    I'll do that.
    JohnnyReboot:
    My Avid Attic resides in C\Documents and Settings\All Users\Documents\Avid Media Composer...and 9 other Avid specific folders also reside there...which is why I'm mildly concerned.
    Thanks again.
