Latest post Tue, Jun 1 2010 8:28 PM by Solopost. 9 replies.
Page 1 of 1 (10 items)
  • Mon, May 31 2010 1:22 PM
    • jmac
    • Joined on Fri, Mar 19 2010
    • Brisbane Australia
    • Posts 12
    • Points 190
    Firewire capture - MC can't recognize my device
    I recently converted from Avid Liquid to MC 4.05 and have been following the tutorials. Thanks Douglas, Larry and others for sharing your knowledge. I have a Panasonic NV-GS400 mini DV cam which I have set up to capture as a generic device and I have no problems. I also have a JVC-SR VS30E mini DV deck but MC does not recognize the device. I am using a Adstech pyro 400 firewire card with TI drivers. The JVC device is recognized in the OS device manager. I have tried  manual configuration, started up the camera, computer and mc in sequence.I have also been through settings-deck configuration-firewire connection-add deck-generic basic dv device but the capture window always shows "no deck". Should I be looking for a firmware update on the JVC device? Is this a W7 issue? or have I missed the obvious? I have noticed that W7 doesn't have the familiar ding dong when a device is connected or disconnected to the firewire card. The onboard firewire card is not disabled. It is a VIA 1394 (I don't use it) and no conflicts are showing up in the device manager.
    Win 7 Pro 64 bit OS; Intel 930 Core i7 2.8 Ghz CPU; Asus P6T-Deluxe-V2 motherboard; Geil 12G 1600Mhz DDR3 RAM; Seagate 500G 16Mcache 7200rpm SATA HDD;... [view my complete system specs]
  • Mon, May 31 2010 2:03 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 10,419
    • Points 123,410
    Re: Firewire capture - MC can't recognize my device
    Hi and welcome here.
    About a week from now, the W7 certified version of Media Composer will be released, I would recommend waiting for that version.
    Mac: 17" Macbook Pro i7 2,66 ghz with 8Gb Ram, 500gb 7200rpm drive___ PC: W 7 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem 8 GB Corsair... [view my complete system specs]
    Tomas
  • Mon, May 31 2010 3:41 PM In reply to
    When you connect the Panasonic to your computer w/o MC on, Windows should automatically give you a option to capture video. Does this alsow happen when you connect the JVC? If not, then it's a Windows issue, IMHO.
    MC 6.0.3.3, QT 7.7.1, Nvidia driver 310.90 (using at my own risk), Window 7 Professional 64-bit SP1, IE9. Quadro 2000 and 600 videocards (four monitors... [view my complete system specs]
  • Mon, May 31 2010 7:18 PM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 427
    • Points 5,325
    I had trouble getting my Jvc sr-vs30u to work under XP-Pro. It finally worked under a generic setting but the audio was bad. I captured the same tape with my Canon GL-2 & everything works fine. I had also used the JVC for 5 years capturing projects in Liquid without any audio problems. I posted on the MC board about this & had several replies but couldnt find them with a search. Maybe you would have better luck with a search?
    MC-6.0.3.4,MB Intel DX58SO i7 DDR3,Intel CORE i7 920,12 G.B.DDR3 Memory,Quadro 2000 Video Card,Driver 275.89,Matrox MX02 Mini/ Max, 2 19" Monitors... [view my complete system specs]
    Regards
    Mike
  • Mon, May 31 2010 7:47 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 590
    • Points 7,525
    Try to install a differerent driver for your deck. When it is connected, and detected by Windows, then select "Update Driver" and manually select one from JVC. Try this one. I had similar problems with my JVC GY-HD101, and it only worked correctly with the JVC driver - but did not work with Microsoft's default driver.
    Joachim
    SuperMicro Workstation 7046A-3 Dual Xeon (Quadcore) X5550 2.67GHz 12 GB RAM PNY FX1700 Soundblaster Audigy 2 ZS Pro 4 SAS HDD's 300GB 15k (1 for OS... [view my complete system specs]
    Joachim Claus
  • Tue, Jun 1 2010 1:10 AM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 427
    • Points 5,325
    Joachim
    Thanks for the info, I'll do that I've done a clean Win -7 install & waiting to install MC-5
    Regards
    Mike
  • Tue, Jun 1 2010 5:30 AM In reply to
    • jmac
    • Posts 12
    • Points 190
    Thanks Guys ! Should I have Win 7 Movie Maker installed for windows to detect a camera?
    jmac
  • Tue, Jun 1 2010 5:39 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,565
    • Points 18,035
    Not needed... Windows should just detect the camera. If you wish - if you do a search for Windows 7 you may find some users who have had success with earlier versions of MC and W7. Look up the user sverkalo.
    But keep in mind, that using an unsupported OS will yield you no help from Avid and could result in unforeseen problems in the software.
    MC5 Mac Pro 2xQuad-Core Intel 3.2Ghz 18Gb Ram OS 10.6.2 w/mojo 2Tb storage (mixed SATA/1394/1394b) ------ MC5 Macbook Pro 2.8Ghz (mid-2009) 4Gb Ram OS... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Tue, Jun 1 2010 4:46 PM In reply to
    Kent,
    I really don't see why you are keep on refering to me.
    As you say it, it's just like I am the only one who has sucess with W7 and this is far from the truth.
    I don't have this specific camera and I can't have a solution, just suggestions.
    I can help anyone (at a point) that has a Z1, Z7, HV30 and DSLR's.
    And some SD models.
    Desktop
    Zalman 600W/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.5/Corsair 16G DDR3/PNY Quadro 2000D(275.89)/WD VelociRaptor 300@10K(OS)/ 2x2TB WD RE4@RAID 0/LG BH10LS30/W7 Pro 64bit/Symphony 6.5.2.1/Matrox MXO2 Mini/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    IMDbLinkedInTwitterYouTubeFB
  • Tue, Jun 1 2010 8:28 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,565
    • Points 18,035
    solopost:
    If you wish - if you do a search for Windows 7 you may find some users who have had success with earlier versions of MC and W7..
    I have only referred to you in this one because I know that you have success with W7 - I also did reference the member to perform a search for the Windows 7 thread that was created some time ago.
    My Two Cents .02
    Kent Brockman
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
