Latest post Sun, Apr 25 2010 11:58 PM by AndrewAction. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Apr 25 2010 9:44 PM
    • titohawaii
    • Joined on Sun, May 14 2006
    • Hawaii
    • Posts 91
    • Points 1,180
    un-collapse
    i am experimenting with the collapse feature. i seem to have trouble "un collapsing" by following any of the options mentioned in the manual. could someone give me a step by step. MC v3
    aloha
    tito
    HP Workstation xw8200 PNY nVIDIA QUADRO FX 3450 PCI-E 4GB DDR2-400 ECC REGISTERED RAM 300GB SATA-II DRIVE (1ST) 300GB SATA-II DRIVE (2ND) ADS... [view my complete system specs]
  • Sun, Apr 25 2010 9:53 PM In reply to
    Re: un-collapse
    Hi Tito,
    Here's what I'd do:
    1. Step into the collapsed effect.
    2. Mark in to out.
    3. ALT+copy to clipboard
    The collapsed section is now loaded in the source monitor without the collapse; un-collapsed, in other words.
    4. Overwrite the un-collapsed section back into the sequence.
    Hope that helps.
    ciao,
    Carl
    Symphony 6.5.2.1, HP dv9605ea, Windows 7 Pro 64, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sun, Apr 25 2010 10:23 PM In reply to
    Re: un-collapse
    This is my workflow for before doing any collapse or mixdown.
    Save the sequence before collapsing.
    Duplicate the sequence and name the duplicate as xxx collapse date time.
    Duplicate sequences make it very easy to get back to a pre collapsed or mixed down timeline.
    Please make Slip and Slide mode selection AND any added new functions available for mapping (to buttons or KB) via the Command Palette.
  • Sun, Apr 25 2010 11:17 PM In reply to
    Re: un-collapse
    I logged a features request for an "uncollapse" function quite a while ago.
  • Sun, Apr 25 2010 11:39 PM In reply to
    • titohawaii
    • Hawaii
    • Posts 91
    • Points 1,180
    Re: un-collapse
    thank you all for your quick response.
    i duplicate anything i am going to mixdown so i will follow the same procedure with the collapse function and save the subclip in the appropriate bin.
    what threw me off was page 254 of my bible (avid advance effects guide) where under to open the nested tracks again:
    those funtions did not work. i have not run across much in the manuals that does not work if i do it correctly so i thought i was missing a step.
    aloha
    tito
  • Sun, Apr 25 2010 11:49 PM In reply to
    Re: un-collapse
    When you collapse a section of the timeline, a submaster effect is created. You can step into and out of that submaster clip just like you can any other nested effect to get to the original elements. Just use the up and down arrow key buttons on the timeline toolbar. You can also double click the submaster and have the collapsed layers revealed above the timeline.
  • Sun, Apr 25 2010 11:58 PM In reply to
    Re: un-collapse
    Larry Rubin:
    I wonder how difficult it would be to convert the current nesting model to a Container model? Instead of Alt drag effect to nest effects something like Alt (new FX button) to open a track based container and have something like the possibilities already existing Avid FX.
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
