Latest post Wed, Jun 16 2010 6:35 PM by OliverPeters. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • Mon, Apr 12 2010 1:27 PM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Jacksonville, FL
    • Posts 1,440
    • Points 18,600
    Re: Arri Alexa - where is Avid in this?
    MC5 looks amazing.  Big kudos to everyone at Avid who helped make it possible.  Pretty clever to incorporate support for the competitor's codecs - let them hash out deals and work with implementing their codecs with different cameras, then support the media it produces!  Especially if ProRes Quicktime playback via AMA is smooth, reliable, and capable of multiple layers of realtime.
    Well done, and the mystery of supporting the Alexa camera has been solved!
  • Thu, Apr 15 2010 1:09 PM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,247
    • Points 30,370
    but, like with r3d files, if you use AMA to cut around on some ArriRaw, can you export an EDL or AFE that can get back to the raw files for finishing?
    Scott Witthaus
    Owner/Editor/Post Production Supervisor 1708 Editorial
    http://vimeopro.com/1708editorial/1708-editorial
  • Sat, Apr 17 2010 3:44 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,993
    • Points 37,720
    switthaus:
    I haven't been able to produce an EDL with imported files, have you?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Sat, Apr 17 2010 5:14 PM In reply to
    TCurren:
    But from what I heard, that is one of those things that are addressed in MC5. Modify imported clips, assign tapenames and additional metadata, and use any metadata from any column as a source in the EDL.
  • Sun, Jun 13 2010 5:58 PM In reply to
    Job ter Burg:
    Sitting in front of MC5, I don´t seem to be able to do just that? Any hints?
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
  • Tue, Jun 15 2010 4:13 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    There's still a problem with QT files. AMA as well as regular imports don't seem to pick up reel names/numbers, even when present.
    - Oliver
  • Tue, Jun 15 2010 4:15 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    PS: You can use Modify to add/alter tape names in AMA files. Doing so only makes this change in the AMA bin and doesn't alter the media file itself, from what I can tell.
    - Oliver
  • Tue, Jun 15 2010 4:31 PM In reply to
    Can you not use something like QTChange to alter the source metadata (TC and source reel) and then manually Clip>Modify in the bin to match? It's a bit of a pain but surely that would allow a finish in a different system (via EDL or similar) even after a transcode to DNx or any .mxf-based media?
    It would be better if AMA could read QT source reel info, of course...
    1xMacPro dual quad 3.0Ghz 10GB RAM with Symphony6 + Mojo DX; 1xMacPro dual quad 3.0Ghz 8GB RAM with MC6+ Kona LHi; 1xMacPro dual quad Westmere 2.4GHz with... [view my complete system specs]
  • Tue, Jun 15 2010 8:17 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Post Republic:
    I have done that and it worked, however, I didn't subsequently export an EDL. I did this with ProResLT files that were converted first from Canon H.264 prior to AMA. I had originally used QtChange on these files, but AMA only saw the TC and not the reel number. I was able to modify the reel number in the bin, but I received a DF/NDF error message for the exact same reel name, so I used a modified name.
    I also tried a test to bring in an FCP sequence and then relink to the source MOVs via AMA. I used an EDL to get the FCP sequence into MC5. I finally got this to work by decomposing the sequence (from the EDL) and then modifying BOTH the AMA clips and the decomposed clips to a new and common reel name. This eventually allowed a relink, but I really wouldn't trust it as a reliable, predictable workflow.
    Clearly it's a trial & error process at this point.
    - Oliver
  • Wed, Jun 16 2010 6:06 PM In reply to
    Interesting. MC5 goes onto the first of our main suites tomorrow and we have a 5D job on the horizon, which we'd like to cut in MC, grade in Color and finish/master back in MC. I'll run some tests ASAP and report on all findings!
    Clearly, MC needs to be able to read QT source reel data for an elegant workflow even to be possible on anything beyond the most simple edit.
  • Wed, Jun 16 2010 6:35 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,795
    Post Republic:
    You might look at Offloader - a new app that Bouke just put out (VideoToolShed.com).
    - Oliver
